drag log sheet
drag log sheet
    Pro Gas Jet RedPearl's Avatar
    Ausitn, TX
    Default drag log sheet
    im trying to find a little simpler log sheet, Ive been using a Mike Kuhl data sheet and the qwik data notes but looking for something a little simpler. if you guys have anything cool please share thanks. Robb
    nitrous guys might like this.
    DataLogSheet.pdf
    Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic!
    Senior Member rampgirlll's Avatar
    Jun 2010
    Ft Worth
    Default Here is what I use....
    DADDY'S DNA #502
    Bitmap
    Bitmap Bitmap Bitmap
    TNT QUAL ELIM 2ND CHANCE
    DATE: TRACK:
    Measurement 1st Pass 2nd Pass 3rd Pass 4th Pass 5th Pass 6th Pass 7th Pass
    Time
    Temp
    Barometer
    Rel. Humidity
    Adj. Altitude
    Air Density
    V-Drive Gear
    Shift Chip
    Main Jet #1 Front
    High Speed #1 Rear
    Timing Retard
    Water Description
    Notes:
    ET
    MPH
    RT
    1/8th ET
    1/8th MPH
    W/L
    Wwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eee
    Mohave Valley/Quartzsite
    Mines pretty simple but it works for me.. I put these sheets in a three ring binder and organize it per race location.. I have a tab for Bako, Dexter, Chowtown, San Diego, Marble Falls, Merced, Phoenix, Redbluff, etc.. Pretty simple. I'm sure someone has something that's better..
    Attached Files Attached Files
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    Ausitn, TX
    Default log sheet
    thanks guys... I got the exact data sheet i was looking for. hopefully these help some other guys.
