Enderle Injection gas or alcohol (methenol)
Results 1 to 14 of 18
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default Enderle Injection gas or alcohol (methenol)
    Whats pro's con's about the fuels? Thinking about going Alcohol !!!!
    Angier, NC
    How far u plan on going
    Quote Originally Posted by swtd View Post
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    One pro on alky........your going to the final round only to find out you don't have enough fuel for It...............dump your 1.75er of capt. Morgan in and take the WIN
    Anyone can pedal a bicycle, can you pedal a flat?????
    It's a sickness Eliminator#1's Avatar
    QC, Mcintyre
    Set it up right with alcohol and you will love it, 1 ?, is it blown?
    LIFE'S GOOOOOOOOD!!!!!!!!!!
    QE 072
    Lake Havasu
    It burns cleaner and won't load up at an idle.
    Your engine will run much cooler.
    Costs less than race gas.
    Uses twice as much.
    Apr 2009
    San Diego, CA
    Do it, but you will need to ditch aluminum tanks and go stainless. Also, buy lots of oil, your going to be changing it a tad more often. Methanol make your motor oil turn milky.
    Sep 2008
    beaumont ca
    Default Tunnel ram
    Quote Originally Posted by Eliminator#1 View Post
    will be a birdcatcher with a weiand t-ram. Bracket boat. 474 c.u BB chevy gen 5 steel gm crank, eagle H beam rods 13.5 cp pistons, 680 solid roller jet boat cam, comp roller rockers K.E. 320 aluminum offshore heads. gear drive, zig mag. have zoomies and bassett hedders. The hull is 900 pounds as you see it with goodies attatched.
ID:	127992   Click image for larger version.
Name:	P1316473 southwind off trailer for weigh.jpg
    Senior Member TIGEDLR's Avatar
    Jul 2010
    I have a similar set up and love it
    QC, Mcintyre
    Quote Originally Posted by swtd:1473761
    I would definitely run alky!
    QE 072
    Upstanding Member Sharp Shooter's Avatar
    The Parking lot
    Methanol:
    The tuning window is larger.
    The maintenance is a little bit of a pain.
    Can be a little harder to get.
    Bigger bang in the cylinder.
    Usage is double.
    6TH STREET TERROR 4 HIRE -RUSSO-'s Avatar
    HESPERIA.
    With alky you will have to use a fire suit if racing?
    I like the tunnel ram injection idea and want to run it on my boat also but looking on the net it is kinda hard to find info on..
    TIGEDLR.. Your boat looked like it was movin last weekend and looks great!
    -FIX IT FASTER-
    -6TH STREET MAFIA -NOMAD-
    Sep 2008
    beaumont ca
    Default combo
    Quote Originally Posted by TIGEDLR View Post
    How does your combo run?
    Sep 2008
    beaumont ca
    Default Info
    Quote Originally Posted by -RUSSO- View Post
    Call ask for jim at Enderle and also Good vibrations in Whittier. They know all about these setups. Great help
    Jul 2010
    Thanks, we had a great time. Lots of cool boats.
