methenol consumption?
Results 1 to 14 of 23
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default methenol consumption?
    What is the quarter mile consumption of methenol full throttle? then consumption for pleasure running? just cruising mead or the river? thanks. looks like 270 for a 55 gallon drum or 30 bucks for 5 gallons. I have tank options for the boat. SWTD.
    Atlanta, Texas, United States
    Quote Originally Posted by swtd View Post
    One will use approximately two times the amount of fuel on methanol as compared to gasoline. The methanol air to fuel ratio is approximately 6:1 to 8:1 as compared to that of gasoline at 12:1 to 14:1.
    i'm back!! 1QuickCP's Avatar
    Montana
    Remember as well its 2 times the use for the SAME HP level, and the alcohol motor usually makes more power so trust me you use a LOT for a weekend, typical use in my blown alky deal for 3 days was about 125 gallons sking ect....same deal on gas about 55 gallons. And remember that you should drain it dry every time as alky picks up water really quick sitting, double oil change frequency as well cause you will contaminate your oil on alky really fast,and it tends to corrode everything it touches. E85 would be the way to go if you have it in your area. Oh race use great fuel, pleasure use...ummm not as much
    Craig- is that machine going to be ready within the next 3 weeks?
    Sep 2008
    beaumont ca
    Default 3 weeks
    HI TOM. not sure about 3 weeks but definatly next season. i will need seat time. lots of it. Getting all the stuff together to get Enderle system together. tired of carbs. Doing it once and for all so I can start the 540 build next year. Will make Ervine deal in October definatly. You Irvine?
    Sep 2008
    beaumont ca
    Default pleasure
    Quote Originally Posted by 1QuickCP View Post
    would really be running practice launches and short spurts more than anything. nothing like a mile full throttle run on river or lake.
    It's a sickness Eliminator#1's Avatar
    QC, Mcintyre
    Your deal should use roughly 2 gal per pass from what I have seen for a non blown deal
    LIFE'S GOOOOOOOOD!!!!!!!!!!
    QE 072
    Sep 2008
    beaumont ca
    Default Thanks
    Quote Originally Posted by Eliminator#1 View Post
    Thanks for info. Damn boat will drink as much as i do. BURP.LOL
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    Dude, get back to work, you got to much free time on your hands
    Anyone can pedal a bicycle, can you pedal a flat?????
    I ditto what qwikcp is saying. if you are running alky in a dual purpose boat the maintenance goes why high! For a week-end normally its okay but after the race or weekend better plan on draining every thing and running marvel oil thru all lines and the pump and the valves and the barrel valves and the nozzles! Reason being is that methanol alcohol absorbs moisture at a very rapid rate and the next thing you know you have jelly showing up everywhere. For me it is worth the extra work for the bang for the buck and the fuel cost! my 02. M
    Sep 2008
    beaumont ca
    Default Hey you!
    Quote Originally Posted by fireboat607 View Post
    Isn't internet awsome......LOL I am going METHANOL!!!!!! Good Vibs tomorrow morning!
    Sep 2008
    beaumont ca
    Default Elsinore
    Will PM you in a couple weeks to break in motor at the lake and check out plates. also we have a sea doo to tow to RUN SPOT
    QC, Mcintyre
    also gorr is in havasu, he is pretty good
    QE 072
    Sep 2008
    beaumont ca
    HEY MISTER you wanna talk about free time!
