Advice
Results 1 to 14 of 17
Advice
    Aug 2010
    Shawnee, OK
    Default Advice
    I currently have a 1974 Tahiti with a Ford 460 and Panther Jet. I have a opportunity to pick up a 79 Galaxy with a Berkley that is already set up for a 460. The Galaxy seems bigger and has a back seat (which I need) but the wood is rotted and needs replaced. Should I just build a back seat for the Tahiti or just go ahead and get the Galaxy and sell the Tahiti. It would probably be pretty even money wise in the long run.
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    alot more options with a berk squirter
    Aug 2010
    Shawnee, OK
    Quote Originally Posted by justsquirtin View Post
    Yea that is why I am considering it.
    Jul 2009
    Hesperia California
    Lightbulb
    I would say, if it ain't broke don't fix it. buy the other boat and make a project out of it and have fun with the one that runs.
    pics...
    Made In The Shade
    Custom Window Tinting
    Aug 2010
    Shawnee, OK
    pics...
    79 Galaxy
ID:	128061   Click image for larger version.
ID:	128062   Click image for larger version.
    Sep 2009
    Chicago, IL
    Quote Originally Posted by jet pilot View Post
    x2
    I understand the temptation, but by all means don't screw up the one you already got working! I can't ever keep mine running, so if you're water ready, I say, keep her wet!
    Aug 2010
    Shawnee, OK
    74 Tahiti
ID:	128065   Click image for larger version.
ID:	128066   Click image for larger version.
ID:	128067   Click image for larger version.
ID:	128068   Click image for larger version.
    Looks like the galaxy has a je pump. Might just run what you have and decide to get a better hull later with full stringers and a jc pump.
    Made In The Shade
    Senior Member HotRodJosh's Avatar
    Oct 2010
    Spanaway, Washington
    Build a seat for the Tahiti....good looking boat. My Kona had similar deck treatment.....before I redid it...
    DITTO. The je pump is a step or two lower than the panther you have and alot easier to glass in a jc or jg in the future if you opt (which I would )to keep the tahiti. Plus you may want to check the opinions of others on which hull was a better build from the start. MLAO M
    Just thought I'd add this since time permits now .... Boy theres alot to ponder when comparing an Berkely "E" jet to a Panther Jet ,A Panther jet is an Axial flow jet and provides acceptable performance with small to moderate HP. The Panther has however serious limitations in terms of improvements and or modifications and for that matter even general repairs (with the exception of the "energizer") and in todays world may this jet be fast approaching obsolesence , a 12JE Berkeley insert mixed flow is conversley is great Jet drive , very closley related in design and function to its 12j C,G siblings , shares 80% of the same original components can be upgraded with everything available to its "brothers" except the actual intake , and loaders and its even remarkabley similar to few AT, Dominator and Legend offerings. With very little work effort can be made to perform exceptionally well indeed ..... Tom
    These pics should provide some "C" vs "E" "contrast" ...............
    Aug 2010
    Shawnee, OK
    Well I was made an offer I couldn't refuse. I traded a car (that I wasn't using anyway) that was maybe worth $1,000 for the Galaxy and he is doing the labor of swapping my engine. I am also getting a Edelbrock intake and 460 heads. I guess that seems to be going against most of the advice here. The Tahiti does have problems though that I didn't go into. The left gas gauge doesn't work, and there is something in the right tank that is blocking fuel. I need to pull both tanks and then glass them back in when I'm done fixing the problems. I have decided that once I get the galaxy the way I want it, I will get another 460 and put it into the Tahiti. Also the Galaxy hull is in much better shape then the Tahiti. All that being said, how do I verify which Berkley pump I have?
    Senior Member GRoper's Avatar
    There should be a tag on the suction housing stating what it is
