set back pump
Results 1 to 14 of 18
set back pump
    MPR FAB southwind011's Avatar
    riverside ca
    Default set back pump
    I have a 18 ft southwind with a Berkeley jc and the intake is out of the hull.would it be worth it to set the pump back since the intake is out of the boat?Right now it has a stock BBC and i plan on building around a 500hp motor with in the next year or two.what would be the pros and cons of doing the set back now.I have a bad porpoise with the stock setup.would this help me or not?
    Senior Member ugly duck's Avatar
    Jul 2010
    OGDEN UTAH
    we recently set the pump back and blueprinted the bottom of that same model boat ,along with machining the intake for a ride plate and built the plate installed it , the boat runs very nice now and we picked up a bit on the mph side. the owner is running a healthy ford (sin) and at 6200ft adjusted elevation hes running 83.4 gps that's damn respectable at this altitude with a aspirated pump gas motor so yup id go for it
    (GN7)Just a simple waste of perfectly good sour mash. If you need a fuel, use something that will poison you, not something that makes you buzzed.
    Quote Originally Posted by southwind011 View Post
    DO-IT. I have done a few of the early 18 southwind v-bottoms and nothing wakes them up faster. I have gone 3" back and my son is building one as we speak and he went out the back with it. You HAVE TO set the bottom up correctly for it to work proper. M
    Senior Member zacho!'s Avatar
    tucson, Arizona
    X2. I set the intake back 3" on my Kachina (very similar if not splashed I believe), and best mod to date. My Buddys boat on the other hand,with with same everything pump and similar HP and semi v hull, feels dangerous to me. He's got 3/4" hook the last 3 or 4 feet of hull. Not fun to drive, let alone ride in...
    Edit: I just read futs' reply and reread OP - must've missed the porpoise statement. never had anything weird prior to set back in my deal...
    Senior Member Futs's Avatar
    Orange CA, Big River
    opening a big can of worms...........jmo
    B1 Racing cs19's Avatar
    I agree, can be made to work really well but you gotta be careful. Thing could be worse as far as porpoising goes.
    With all due respect futs and cs that is why I stated the bottom must be set-up as well. Along with a ride plate,shoe and diverter. If he has the intake out now then do it now. Do it right the first time and be done underneath. M
    Could you elaborate on what you would do when you say " bottom set-up" Are you talking just make sure there's no hook, or do you need to create a Delta pad? Is there some sort of standard or starting point? What is the criteria when considering a set back pump? Inquiring minds are also curious.
    tucson, Arizona
    Too much hook is very bad in my humble AZ experience...
    So are you guys looking at the rocker that was built into the boat? Some people place there straight edge right on the rocker and think, wow, this has a ton of hook because the straight edge has a 1/4" gap or more, when in fact that rocker needs to be there to let the boat roll over so to speak. I hear everyone talking about hook, do most not know about rocker?Set backs have a time and place. It can work well on one and do terriable things to the next. If this is a ski boat and your looking to enjoy it, just leave it alone. If its an all out max effort, well, then cut the intake for a shoe, move it back a few inches, and get the bottom done. Then let the headache start when you cant figure out how to hardware the thing and your wasting your time dicking with the boat rather than enjoying it.
    Dont get me wrong here, Im all about performance, but when your taking a 1/4 stringer boat and seting the pump back, its going to do funky things to the bottom as far as structual integrity.
    This is just my opinion. im not a know it all, just been around for awhile and seen some stuff....
    Agree with Tim , (potential "worm can" as you were advised above)not every boat will benefit from this , try to sort out and diagnose whats causing the porposing problems with the original setup vs making a huge and significant modification that will require a whole new set of changes and adjustments , pics will help (bottom ,intake area ,jet etc) could be something simple Tom
    riverside ca
    What would be the cause of the porpoise with the stock set up? Also I will be replacing the 1/4 stringers with full stringers. Dose anyone have pic of there set up?I would like to see the difference from stock. Thank for all info.
    Senior Member bp298's Avatar
    LHC
    knew a guy many years ago that had a sw splash. would run 88 through the traps porpoising like a mother. he tried everything; droop, no droop, short plate, long plate, diverter, bottom blueprint, and everything in between. still porpoised. after exhausting everything he and others could think of, he finally added trim tabs, adjusted them once and the porpoise was gone. and then it would run over 90.
    nobody really wants to add trim tabs. but it's a sure way to eliminate porpoise. sometimes ya just gotta do what ya gotta do...
    Senior Member stoker2001's Avatar
    Folsom,Ca
    what do i know,but tunnel tabs are mounted on top of tunnels and can affect handleing as well as trim tabs that are mounted level with bottom of boat..
    Whacker Smacker M/E #561 IHBA "first looser"champ 2006&2007&Sportsman Driver of the Year
