Impellor chart question.
    Aug 2009
    Fox Valley Wisconsin
    Default Impellor chart question.
    Can anyone tell me if a tight pump reads differently on a impeller chart than a loose one as far as H.P. goes. Also does it change if there is a stuffer installed.
    Senior Member ugly duck's Avatar
    Jul 2010
    OGDEN UTAH
    it will make a difference (both) how efficient your pump is and if its properly loaded vs cavitating as far as a chart that factors that i haven't seen one not to say theirs not one out there
    (GN7)Just a simple waste of perfectly good sour mash. If you need a fuel, use something that will poison you, not something that makes you buzzed.
    Senior Member Mash on It's Avatar
    Willow Beach & BHC
    A tight pump WILL take more hp to run
    Lost 350-400 rpm after rebuilding the pump and detailing the ss impeller, gained better holeshot, top speed about the same.
    Thats on my JUNK
    Thats all I got
    Daniel
    Mash on it
    Aug 2009
    Thanks. Was just wondering. Had my motor rebuilt and pump gone thru a stage 2 with stuffer. Hole shot and acceleration great. Top increased some. Big ole "AA' SS imp. Just when I referenced the chart it had less H.P. than Before the rebuild.
