Place diverter modify for bigger roost
Results 1 to 5 of 5
    Jun 2011
    Default Place diverter modify for bigger roost
    Just put place diverter on first trip out alot of fun but i want bigger roost. Its a berkley 12 jc bowl i know you can do more with split bowl but i have heard guys modify the place diverter as well just need to know how and were to modify!
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by MADMAN View Post
    Theres a good thread in here somewhere that shows you where to grind, just becareful and don't grind to much
    Jun 2011
    Default Bump
    Bump !!!!!!!!!!!!!!!!!
    Mar 2010
    Clarksville, TN
    If you grind or modify the "up stop" (housing) you run the risk of adversly affecting the inner double seal function and overall operation of the trim unit itself , if you goal is to simply make a bigger "roost" maybe consider a wedge (split bowl only) Tom
