How much $$ to do a full rebuild on my 12JE
Results 1 to 8 of 8
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Default How much $$ to do a full rebuild on my 12JE
    How much does it normally cost to have a shop do a full rebuild for a berkeley 12je pump tthat is still on the boat and motor still attached does motor have to be pulled. Just looking for what u might think it will cost thanks....
    Quote Originally Posted by corbin5754 View Post
    Thats a pretty generic question.....You just lookin to replace the thrust bearing and wear ring? Or are you thinking new impeller....race shaft ect. If I am not mistaken either the motor has to be pulled or the jet....for me it was easier to pull the jet but I have never worked on an e pump.
    Aug 2011
    indy.
    No the impeller is good stainless
    B1 Racing cs19's Avatar
    It all depends on wether the front part of the drive would need to be serviced meaning the front bearing, when was the last time it was rebuilt? To service that you need to remove the engine. Your probably looking at an additional $250-$350 to R&R the engine depending on where you go, or do it yourself if you have the means.
    Chris
    Dallas, TX
    Contact Tom @ jetboatperformance. If you are mechanical at all he will help you get what you need to do it yourself.
    Avondale,AZ.
    We are in the Phoenix,Az. area and would be glad to help. TIMM 623-877-8553
    Senior Member Cobra 02's Avatar
    Montclair
    x2 Tom will walk you right thru the process, did mine last year with the help of Mr. Tom...
    Aug 2011
    indy.
    Right on guys i appricate the help when boating season is over i plan on getting it done thanks...
