trick to removing a rub rail..
Results 1 to 8 of 8
    Jun 2011
    Dallas Tx
    Default trick to removing a rub rail..
    I'm in the process of sanding my boat and i don't truely know how to remove the rub rail. I was using brute force. I believe it's pop riveted, and when I pry on it the heads pop off. Any trick of trade I'm missing?
ID:	129006   Click image for larger version.
    The Earth
    Blog Entries
    24
    Drill em out. Reinstall with ss Screws not pop rivets, and in new holes (silicone the old holes up). I have all types of popular RR if you need when time comes.
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by ItsJohny View Post
    Remove the rubber and then drill out. U may need to drill at an angle if the rivets spin.
    Dallas, TX
    Salvage that rail if you can. It is about $100 a stick and another $100 to ship it.
    Oct 2010
    Lake Dallas TX
    geezzz...
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Wow! I guess you could just rip the RR off the boat.... yes a drill is the tool of choice, and also another way to reinstall the RR is using rivets. typically I have never had new RR fall into the same holes....EVER! Also, if/where possible, you can attach a small washer to the back of the river and I assure you, it will never come loose, unless it gets manipulated.
    TRG
    Jun 2011
    Dallas Tx
    Thank you for the quick responce, I will keep you in mind when i do buy some.
    Last mohican -"Salvage that rail if you can. It is about $100 a stick and another $100 to ship it."
    Wow didnt know that, they are wadded up in a pile... Thanks anyways man.
    TRG
    ya lol just brute force... drill worked out 10000x better think ill avoid rivets to save the next person the pain in the ass
    Silverdale, Washington
    Cap it???? I know, I'm weird but I thought it was kinda fun
