never had this issue
Results 1 to 11 of 11
    bullhead city
    Default never had this issue
    took grandkids out for ride, new motor running good about a couples miles before we get to the rampwater pressure pushed the gasket out of the thermosate housing, got the kids with hot water but no burns, I guess I need to check water pressure, also noticed that when you slow down temp goes way up then comes right back down and it never did that before it come up slowly to about 1/2 and stay till I speed up
    Cas
    Cas is offline
    Angry American Cas's Avatar
    sounds kind of like there's a blockage in the dump lines somewhere not allowing the water to flow through the system.
    Sep 2009
    Chicago, IL
    Not to jack the thread, but that sounds similar to the problem I was having. Would the dump lines be the water injection to the headers (OTT headers), or would it be the bypass...or both?
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    would be your water line out of the block to transom-
    Quote Originally Posted by hihosilver View Post
    First off! Glad the kids didn't get burned. second does it have a thermostat. If not you have a exit limiter somewhere holding the water in to long which is proven by the fact you need to get on it to cool it down. My 02. M
    bullhead city
    no thermo, but line out the back flows better than it used to, headers a little less, I will put a new gasket and set up a pressure gauge, the only things changed were the heads and intake, thermo housing and lines are the same
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    Where do you store the boat? outside? if so a "dirt dobber" as we call em down south will/can get deep in the line and block it up, and water will not get the clog out on its own most of the time.
    bullhead city
    boat is stored inside, but will blow the lines out
    bullhead city
    well found the problem gasket surface on the intake( used) I will be sanding for a bit, everything else is good
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Still check your pressure....
    bullhead city
    will do
