[Question] Hyd Place Diverter limit / stop
Results 1 to 6 of 6
    Feb 2009
    MANTECA
    Default Hyd Place Diverter limit / stop
    Im having trouble with my place diverter stop. It came with the setup and basically it is a 3/8 aluminum plate that clamps to an aluminum sleeve that protrudes from the bottom of the hydraulic ram.
    The problem is that it moves and the adjustment goes away. If I tighten the clamp too much it locks the ram up. I can think of a few different ways to improve on the design,such as having it clamp to the bottom ram as well, but I just thought that with all of the people running this type of setup..........maybe someone has a stop that works better.
    Thanks for your suggestions, and pictures. Here is a picture of what I have.
    Chris
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    I have the same type of stop with no problems. you should be able to tighten the clamp without squeezing the ram. I'm thinking the hole isn't big enough. If you drilled the hole the same diameter as the ram then cut the slot, the thickness of the blade used will change the diameter a little bit smaller. Try opening the hole just a scosch and I'm sure you'll be happy with it. I also noticed you dont have the stop all the way up againt the bottom of the ram. Is that as far as you cam get it on? If so you should have plenty of material to remove to get it flat against the ram for added stability.
    Feb 2009
    MANTECA
    Default Thanks
    Quote Originally Posted by bwurst1 View Post
    The stop was up against the bottom of the ram when it was adjusted (at the house). The next day I went to the lake and was trying to get it adjusted and it seemed like I just couldn't get it dialed in. I would jump in and give it a couple half turns (underwater). When I got home and looked closely at it I realised it must be moving. Thats how far it moved in a day at the lake . Thanks for the info, I will take the ram off and see if the hole is a little tight on there.
    Chris
    okie, lake Texoma
    this is how I did it
    H8-2-W8
    [email protected] first pass
    Positive Vibration Dread Pirate of Humboldt's Avatar
    Humboldt
    Mine has a pretty simple and effective stop. I can't find a pic, but will take one as soon as I can.
    Feb 2009
    MANTECA
    Default ????
    Haas,
    Is that just all thread with a sleve over it? I was thinking about something like that, but I wondered if it might try to bend with the greater distance. Nice setup
    Chris
