Gas valve?
Results 1 to 7 of 7
Gas valve?
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Gas valve?
    Any of you guys use a ball valve to control fuel? I run two tanks into a water separator and then into the pump. I'm thinking about putting ball valves in between the lines from each tank. Not sure if these would hold up to fuel.
    Jun 2011
    spokane, wa
    We use those valves on a buddies boat and have had zero issues with them!!
    The Man cordog009's Avatar
    East Texas
    Both of my tanks have ball valves coming off of them. Just remember to check them when you switch tanks and wonder why you don't have any fuel pressure
    1984 Youngblood TX-19 SOLD
    whats a goodtime cost? Nixonnow's Avatar
    Feb 2011
    Fort Mohave, Arizona
    i have the same setup that your describing and am curious to see the replys in this thread. i also was thinking of putting ball valves in my system so i can select between tanks.
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    i had the exact set up on my last boat, a 1/2 NPt nipple out of the tank directly into a ball valve, then to the water seperator, then on to the pump! These are virtually indestructable with modern fuels. I have run Pump gas, C12, and Avgas through the same valves for three years, and the previous owner had them in the boat for who knows how long.
    Been using thsoe for years with great sucess Tom
    Jun 2011
    Dallas Tx
    Just make sure it is has " GW " ( "G" meaning gas / liquid petrolium and "W" being water rated ) on it. Those are what we use for commerical gas applications.
