Voyager ignition?
Results 1 to 5 of 5
Voyager ignition?
    Jul 2011
    Rialto,CA
    Default Voyager ignition?
    Hey all,
    New to the forum and to boating. I picked up a 20.5' 95' Advantage Classic open bow with a from what I know stock BBC (gold roller rockers when I look in the valve covers) and a American Turbine pump with a B impeller. I took off the Edlebrock 750 carb and Carter electric fuel pump, I installed a Holley 750 DP and a Holley red electric fuel pump.
    The problem I think I have now is the Voyager ignition. It is very inconsistent with the issues. Sometimes I can run at WOT and hit 5k at 52MPH and then it will instantly drop to 4500 and 45MPH like I left off the gas. Sometimes I will be cruising at 3700rpm and it will start popping like it has hit the rev limiter and then stop when I rev it up to 4200rpm.
    I tried to set the timing but when I plugged the shunt into the distributor the idle dropped to low for me to keep it running with out revving it up.
    Should I look into a big cap HEI i.e. D.U.I.? I don't have the funds rite now for MSD and don't know if I need it.
    Thanks for the help!
    Inland Empire-Big River
    Quote Originally Posted by Hillbilly Deluxe View Post
    Hey all,
    Congrats on the new boat and welcome to the boards! I recognize that shirt
    Richard (Sunstate)
    We wash our parts in gasoline,
    We drink Alcohol,
    And we go racing with Nitro-Methane!
    okie, lake Texoma
    Get rid of the holley red and check your fuel filters. Sounds like your running it out of fuel. Dont keep at it or you'll hurt it. Your ignition is probably fine.
    Look into a good mechanical pump.
    H8-2-W8
    [email protected] first pass
    Jul 2011
    Rialto,CA
    Quote Originally Posted by rivrrts429 View Post
    Richard (Sunstate)
    Thanks Richard, we will have to meet up some time on the water, not over a hot BB-Q!
    Jul 2011
    Rialto,CA
    Thanks for the quick reply. I have changed all the fuel filters and bypassed the fuel water separator, still no luck. I will replace all the fuel lines and then get a mechanical pump.
    Any other suggestions?
