problem with diverter pump
Results 1 to 6 of 6
    Member lenker's Avatar
    Costa Mesa
    Default problem with diverter pump
    I read through some of the old threads checking for common problems with these Bennett diverter pumps. It worked perfect all weekend and all of a sudden, nothing... I read that some people have had stuck solenoids and to tap on them. I did that and nothing. When I press the up and down the wiring seems to start getting warm. I also Read about diodes going bad or somethin like that. I'm Not sure how to test all this and pin point the issue. Any suggestion would be greatly appreciated thanks
    Brett Lenk
    Missinglenkmotorsports.com
    Sep 2008
    Yuma, Az
    Quote Originally Posted by lenker View Post
    if the wires are getting hot, then your wiring needs help. check the switch (up and down) and trace the hot and ground directly to the source. its better to run them from battery. the positive is best ran on a relay then to the switch and ground it to the battery. when the wires get hot, its usually the "hot" wiring grounding to something it shouldnt be.
    boatless....
    Costa Mesa
    It's not poping the fuse tho, that what has me startled...? I hear the pump trying to work also..?
    Brett Lenk
    Senior Member Futs's Avatar
    Orange CA, Big River
    unscrew the solenoid and see if the check valve is stuck.
    As Tim suggested check the solenoids , unscrew/loosen and re-tighten to a lite seat Also VERY important check (with digital multimeter) for a solid ground and 12v signal , call if you need tech help ! Tom
    Costa Mesa
    Thank you so much guys..
    Brett Lenk
