Little help guys
Results 1 to 13 of 13
Little help guys
    Member SUPA SANGER's Avatar
    K TOWN
    Default Little help guys
    After eight years of excellent service it is time to pull the Sanger down and do a complete trailer up rebuild. after pulling the carpet to replace the floor, I ran into question # 1. the guy i bought the boat from attempted to remove the foam from under the bow and left a complete mess. i will be cutting it out during the rebuild but my question is how or what do i replace it with? thanks ahead of time.
    R.I.P. MR. & MRS MATTHEWS
    Oct 2010
    661 So. Cal.
    Quote Originally Posted by SUPA SANGER View Post
    What type of foam is up there???? When I bought my Sanger it was full of rotten bags of packing peanuts. it was a mess like you have never seen. it took a hose and a garden hoe to get it all out. If it is A/B foam (expandable) and everything is stripped out of the boat interior wise (since you are going full redo i'm guessing it is) I would get after it with a pressure washer. It still makes a mess, but it makes quick work of it and also keeps you at a distance from the mess.
    SJ
    PS..... remember to post s build thread with lots-o-pics
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default forward bow
    Insert an automotive tire vor truck inner tube in forward bow if you have a forward bulkhead and blow it up for flotation.
    Youngster Hagan's Avatar
    Aug 2011
    Salem, OR
    You will need to replace it will 2 part polyurethane foam. Its really good stuff. (not can crap from home-depot) You mix it together and it expands. It is water proof and provides flotation. It is really dense and hard when complete and will make it rigid. My brother put it under his floor under his '87 Malibu Skier. And I used it on my Jet ski.
    Here is what I bought...I will probably use it for my current boat.
    AeroMarine Products - Polyurethane Pour Foam for Insulation and Flotation
    Oct 2010
    661 So. Cal.
    Quote Originally Posted by Hagan View Post
    A/B foam is good if you dont need the storage, but you need to be carefull when mixing the foam. take into acount the expansion rate because if you mix too much it can ruin your hull. I personally used a truck inner tube blown up in my forward bow as previously mentioned
    SJ
    K TOWN
    Quote Originally Posted by SuperJet View Post
    SJ
    its the expandable foam. its was in a square shape i will try to post a pic. thanks for the help boys
    Mar 2011
    I think is expands 11 or 22 times it size and is strong, the wrong mix can break the hull, i know a guy who bluids race boats (problem child) and he said to mix a little at a time, he said they hole saw spots in the new floor and pour it in, that way it has somewhere to go and you creat a stronger hull that way.
    San Francisco Bay Area
    Cool
    Quote Originally Posted by swtd View Post
    x2. The inner tube is functional, removable, servicable, replaceable. The foam is permanent, messy, deteriorates, and can trap water and weigh down the hull.
    LO
    High Flow Dynamics
    Southwest corner AR
    Noodles work also! You can cut them down or leave them long and they don't loose air!
    WT
    WFL Crew!!!
    K TOWN
    Great ideas. I will be opening a rebuild thread as soon as i figure out the pic process. I have some on photo bucket to post. Thanks guys
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    I put three 24" excercise balls past the bulkhead and inflated them. They blow up large enough to hold themselves in place.
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    By chance are you referring to the noodles used for swimming pools? I had that same idea when I saw a box of them at the Dollar store LOL. Any Idea how many it would take? I figured 1 floats me and im 170lbs. So 10 would probably do it. or am I off on this one?
    Quote Originally Posted by mrjoshua View Post
    DITTO, They come in different sizes to work with the area. M
