Daytona Deck side profile Pic
Results 1 to 8 of 8
    Las Vegas, Nv
    Default Daytona Deck side profile Pic
    I need a picture of a side view of an Eliminator Daytona Deck, from the dash to the nose of the deck, as close up as it will ge to show the entire lenght of the deck.
    What I need to see is the shape and roundness of the deck and the way it tapers down to the nose.
    I also need dimentions of the two ribs that run up the center of the deck. Any help would be greatly appreciated......Hal
    Hal, have you considered checking with Eliminator or GS Marine to find out if they would lay up a patch panel? Sure would make the repair a lot easier........
    Jun 2011
    spokane, wa
    Sounds like this hull took a hard hit.....?? Do yourself a favor and contact GS marine or maybe Chris Starkweather @ B1 Racing can help you out, do not hurt yourself man!!
    Silverdale, Washington
    Hal, just to be sure, you need these measurements and pics for a 19' Daytona correct?
    Las Vegas, Nv
    Oldsquirt, that is not a bad idea. Thanks.....Hal
    Senior Member bp298's Avatar
    LHC
    right now, scott kornowski is replacing 3/4 of an entire outside sponson on a dcb 35 that ran through a boulder. and it'll look like new when he's done with it. if you've got a significant glass/structural repair, he's the best. and... he's in havasu.
    Las Vegas, Nv
    Hey John Yes It is a 19 daytona. Thanks.......Hal
    Sacramento area
    Can you use the piece you cut out to make a mold of what was there? Then layup the new deck in the mold.
    I gota tell you. I have taken on some over the top projects, that most say "what were you thinking".
    This is a project I'm saying "Man are you brave".
    I'm looking forward to seeing your progress. Give me some specifics on pictures and measurements (how and where). I'll measure and take photos of mine for you. Be safe, schick
