Comp Cam Blet Drive - Replacement Belt 6200 TB
Results 1 to 3 of 3
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Comp Cam Blet Drive - Replacement Belt 6200 TB
    November 10, 2011
    Hello People,
    Anybody having trouble with the Replacement Belt 6200TB2
    The new belt lets the cam walk in the teeth
    Willis
    Put a plate on it.
    Member Boat 104's Avatar
    San Marcos, Ca
    [QUOTE=willis;1523402]November 10, 2011
    Hello People,
    Willis,
    And I thought it was just me, Comp cam belt system experience not been pleasant, out of the box the first belt fit so tight that you need a 3 foot breaker bar to turn over the engine with cam and crank only. Comp cam admitted they had a batch of short belts out there. The replacement belt they sent fits as you are explaining. Although I don't feel real comfortable with it, it has been working just fine. The movement I have it less than 1 degree. Hook up with Tom or Todd Fulkerson, they have been doing some in depth investigation on this subject. Steve
