79 Sanger super jet overhaul
Results 1 to 14 of 16
    Senior Member sturat's Avatar
    Houston TX
    Default 79 Sanger super jet overhaul
    I figure now that most peeps are done boating for the season I will start a build thread on my Sanger over haul.
    We all know how what appears to be a minor repair snowballs into a major undertaking.
    What started out as a sub floor delam issue evolved into a full and complete make over.
    Here is the before picture.
    Legalize the Constitution!
    Houston TX
    Default First repair
    Pulled the old carpet out to repeair the sub floor delam and made the repair.
ID:	138628   Click image for larger version.
ID:	138629   Click image for larger version.
Name:	delam repair.jpg
    Houston TX
    Default maiden voyage
    Took her out after the repair for a trial run and then all hell broke loose.
    Went to the cove where everyone was hanging out on the lake. Made a few passes with the better half, then decided to make a solo pass.
    Made my pass and then headed back to the beach,then my feet was greeted with a wall of water. I thought what the hell, maybe the bilge stopped working so I turned around and all I saw in the bilge area was about 8” of water.. Said oh $hit I have a big problem…
    Boat was still running and I was about 300-400 yards off the beach, so I hit the gas and headed straight for the beach. Beached it and got it on the trailer.
    Here are the results of my trip.
Name:	inside crack.jpg
ID:	138631   Click image for larger version.
    Houston TX
    Default getting ready to take it to the glass shop
    So we get the boat home and ready to go to the glass shop for the crack repair.
    Left the boat at home and went to get it during lunch to run it to the glass shop after work. When I got home i saw this...
    The tanks where full as i only ran it for a short time before it cracked. It was 100+ outsde and my damn tanks boiled over and ate the paint off the side of the boat. Once this happened i figured i have been wanting to change the paint schme a bit.. hence snowball part three...
Name:	paint boo boo.jpg
    Houston TX
    Default Snowball part 4
    well since i had to rip out the sub floor to repair the crack in the hull, might as well change it from 1/4 stringer sled to a full stringer sled.
    So the old stringers and bulk head where removed and replaced with full stringers and new bulk head.
    We added a piece of quater round in the radius of each lifting strake to avoind this from happening again. We also added a complete layer of glass on the floor from the bilge area forward.
    This is where sge is at now, I need to save up some cash to buy the paint so we can reapaint the whole sled.
Name:	old stringers out.jpg
ID:	138637   Click image for larger version.
ID:	138638   Click image for larger version.
    Senior Member flattie's Avatar
    Menominee mi
    looking good.... Im in the process of doing a 78 super jet. Not to jack your thread but here are a few pics of what im doing
    Took the deck off mine. Made the project lots easier in about 20 mins
    Menominee mi
    Next I cut that ugly ring off the back. Made it way easier to set the pump back. Put full length stringers in it and new bulkheads and capped the deck back on so far.
    Menominee mi
    Pumps set back now all holes filled in the dash and gelled the cap and transom. asl of right now I have the boat upside down getting ready to blue print the bottom and take whats left to the hook out
    Senior Member isanger's Avatar
    Sep 2011
    Silverdale/Ellensburg Wa
    You both are doing great work!! Keep this thread going Sturat!
    Senior Member 78_Tahiti's Avatar
    North Highlands, CA
    X2 on keep going with the progress of both hulls! I very interested in seeing the SuperJet's Bottom, and its shape. I'm getting ready to start on a Brendella Jet. The bottom is very, very similar to the Sanger Super Jet! Nice work by the way guys!
    Oct 2010
    661 So. Cal.
    I agree, both of you are doing a great job. Flattie, start a new thread for your build and remember to add lots of pics. I too have a SuperJet that I capped and regelled last winter. this winter mine gets a new motor/mounts and possibly a full stringer conversion.
    Houston TX
    Quote Originally Posted by flattie View Post
    I hope you have plans to add a round keel from the delta pad they have now. Just my .02 if not you did a ton of work for no gain.
    I love My Sanger, but they have some issues with power and other mods.
    Boat is looking great!
    Mar 2010
    Clarksville, TN
    Lookin good Stu
    keep the pics coming
    Houston TX
    Lookin good Stu
    Thanks Mike...hope to have it all done and ready to roll for BB on the 4th!
