Impeller Chart
Results 1 to 14 of 14
Impeller Chart
    Senior Member vmaxed's Avatar
    Sep 2010
    EAST LA (Lower Arkansas)
    Default Impeller Chart
    I know I'll print it off this time. Would someone please post up an impeller chart? How many horse power does it take to spin an "A" with an inducer 6000 RPMs.
    Surprise, AZ
    This topic has been beat to death. Use the SEARCH feature and you will find it. Or you could Google it and get your answer.
    Or search on the web. I see you spelled it right. Gets a ton of pics. Like this. Image Detail for - http://www.youngbloodjetboats.com/pics/Impeller_Chart_ExtendedA.jpg
    Heres Duanes (Hi Tech) extended chart , hope this helps it wont factor however the inducer IMO cut the shaft leave out, the inducer drive it for setup first !Tom
    Mar 2010
    Clarksville, TN
    Hey Grady get me a fax number and I'll get you a copy in the morning. But to answer ur question I'm gonna say about 800 HP
    My calculations say 772 HP (w/o the inducer) , so your probably pretty close
    berkley impeller horsepower chart - Google Search
    click on link...... funny I see my writing on a few of those
    S CP
    Sep 2010
    Default Rpm drop
    My old 468 is turning an aluminum "B" 5850 how many RPMS and MPH will I loose putting a SS Aggressor "A" in till I get anew motor built.
    Salem,Or
    Quote Originally Posted by vmaxed View Post
    With my 496 I lost about 200 in rpms going from a aluminum to a SS-A
    With Spray there is a way!!!
    Quote Originally Posted by BrotherWolf View Post
    With my 496 I lost about 2k in rpms going from a aluminum to a SS-A
    2000 ?? Wow
    That has allot to do with the cam/intake combo and trq curve of the engine. If the engine is not "on the cam" you could lose a ton of rpm.
    S CP
    Salem,Or
    2000 ?? Wow
    I ment 200...UGH...NEED COFFEE!!..LOL
    Senior Member bp298's Avatar
    LHC
    about 9 years ago, over a winter we changed from a blueprinted ss b impeller to a blueprinted ss b impeller. the same winter, we made a few changes to the engine picking up 45hp across the whole curve (same dyno, same time period on the dyno).
    the first pass, exact same setup, same water, same weather as the year before, i LOST a little over 200 rpm and GAINED almost 3 tenths (i.e., 10.05 to a 9.78). it's not always as cut and dried as a chart might imply.
    That makes better sense ,and doesn't come as a huge surpize particularly between brands, not so much metal compositins Tom
