TX19 deck
Results 1 to 13 of 13
TX19 deck
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default TX19 deck
    they deck on my TX19 has a dip in it. It is a lightweight hull, should I fix the dip or ride with it. I really DO NOT want to crawl under the deck and glass a brace in.
    Does it have a bulkhead under the deck, or is that what mean when you said you dont want to glass a brace in?
    Led
    Led is offline
    Jul 2010
    yes, the dip is in the flat part of the deck near the front.
    sorry tired of trying to rotate it.
    Led
    Led is offline
    Jul 2010
Size:  70.8 KB ok finally got it.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Take a pair of wood skis. Put one underneath the sag and one upright to brace it up. Wrap some LED lol rope lights around it.
    QE 439 Twin Turbo
    Led
    Led is offline
    Jul 2010
    sounds like a pretty trendy idea.
    It's a sickness Eliminator#1's Avatar
    QC, Mcintyre
    Led, I had the same issue. It's a lot of work to get it straight if you have the time go for it, if not it won't slow it down so really now reason to fix lol
    LIFE'S GOOOOOOOOD!!!!!!!!!!
    QE 072
    Led
    Led is offline
    Jul 2010
    10 4, thanks, I didnt think I was the only one with a Dippin Deck.
    Funny thing! When I was in the market for a CP I looked at a light 18er. From the photos it had the same dip in the bow, I ask what the deal was ( because I hadn't seen in person) I was assured it was a optical illusion. Lol.
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    Optical illusion my a$$! I have seen at least three original TX's that have this dip or wave to them. Most of them were light layups or had wood removed up front to cut the fat. If you have the time, I would say fix it, it looks tacky when someone spends all the time and money to restore one and then doesnt fix something like that.
    Senior Member bc18's Avatar
    leave it
    Iuka, Mississippi 38852
    just take a big inner tube, put it up under there and add air. no weight gain, provides additional floatation, cheap and problem fixed.
    Led
    Led is offline
    Jul 2010
    I was thinking about adding some floatation to the nose, thats one way to do it.
    I am a perfectionist most of the time, and looking out across that deck and seeing a dip may bug the piss out of me, however if the motor is thumping the entire deck may be vibrating so I might not notice.....
