alternator mounting for front motor plate?
Results 1 to 14 of 23
    sacramento
    Default alternator mounting for front motor plate?
    i am looking for ways to mount the alternator . with the new motor plate i can't mount my usual alternator without cutting the mount most of the way out. i am thinking mini alternator. who makes the good alternators ? & or which ones to stay away from. i was looking at the denso or gm style for race 50-60 amp chrome. does any body have pics of other ways of mounting ? thanks ,turbo wog
ID:	140983   Click image for larger version.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    It takes a few spacers. One mount on the motor plate and an L angle on the cyl head slotted for the adjustment. An aluminum turnbuckle for stability.
ID:	140989   Click image for larger version.
ID:	140990   Click image for larger version.
    QE 439 Twin Turbo
    sacramento
    i am not sure it will clear my water log set-up there. if i cut the plate as marked is there enough to hold up ? 3/8 plate going for 1500-1650hp & with nos in the future @2000hp?
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    Hey Wog you've been busy. Mine is mounted like Infomanaics. Not sure there's to many options there. Im think-in you should have clearance between the logs. Where was it mounted before?
    sacramento
    hey ben ! my alt was mounted low on the drivers side. real tight if i remember right. i will mount it on the motor & see how much room there is . did yo buy you mounting kit or did you fab it? clearer pics would be good thanks guys . other options would be good also.thanks again
    The Earth
    Blog Entries
    24
    Default Direct drive if you have the room
    Whitewright, TX
    Hey Mike, do you have that Mercruiser combo bracket (alt/PS pump) MER 806394-A1 in stock? Jocko
    The Man cordog009's Avatar
    East Texas
    Duane at HTP makes a nice one, I've got one of them.
    1984 Youngblood TX-19 SOLD
    Las Vegas, Nv
    I also used the HTP altenator bracket. It is a nice set up. Duane is also, now making an adjusting arm for the bracket. Here is a pic of the whole set up.........Hal
    Nov 2008
    Roseville CA.
    ,Ya mine is fab'd Just a hole thru the 3/8 mount and a bracket for the top. Go to togs they got a bunch sitting in bins there, your bound to make something work.
    East Texas
    Yea I got the adjusting arm as well. Works great.
    We leave a small "Tab" on the left side of our rail mount plates to facilitate Alternator mounting ..
ID:	141051Click image for larger version.
    I cut the upper adj arm out of 1/2" plate and the lower mount out of 2" round stock.
    sacramento
    thanks guys! keep em coming . when i get home i will try to see which will fit bet for me .
