How Much Fuel For A 1/4 mile Pass???
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 43
    Default How Much Fuel For A 1/4 mile Pass???
    has anyone ever measured how much fuel it takes to sit on the rope idling for 35 sec and make a 1/4 mile pass???...N/A...no nitrous...i found a tank i really like for the new boat but its only 1 gallon
    Senior Member 77charger's Avatar
    My comp flat used just under a gallon per run.no nitrous all motor.
    Senior Member Red Rocket's Avatar
    winchester, ca
    one gallon may be pushing it a bit.
    Quote Originally Posted by Red Rocket View Post
    thats what im afraid of!!!...i wish they made this tank in 1.5 gallon...i would hate to find out through the lights that it wasnt enough!!!...thanks mike
    Senior Member bp298's Avatar
    LHC
    about 1/2 gallon. then you find yourself at a place like dexter where you have to drive to the rope and back to the outramp, takes a bit more. but even with that little amount, i'd be concerned with vortexing the suction in a 1 gallon tank if it gets low.
    Santa Clarita
    Never measured but i'd say the 405 uses less than a gallon on N20.... No sure about the 418 but seems about the same... Stark or RJ might know for sure. I'd say about a half to 3/4 of a gallon on N20
    X2 I would shoot for a 2.5 gal tank and be safe. Last thing you want to do is find out it wasn't enough with a single gallon.
    I would think a 1 gallon tank is smaller than advisable. There are to many what if's involved. What if you are given the Ok to start your motor and for whatever reason it starts hard, you have now pumped it several times, but it starts and the motor is running. At the last few seconds before green light, the course is red lit for one of many reasons, you now go through the process again for your run. you have a problem.
    I assume there is a good deal on a 1 gallon tank or you already have one, but it is smaller than practical. Don't consider it for weight as fuel weighs about 6 pounds per gallon and the most weight saved would be 10 pounds.
    Weight is the only thing to consider here...10lbs is alot...if I wasn't worried about weight then tank size wouldn't be an issue
    Have the tank sumped, for a little better low fuel delivery, and capacity.
    LHC
    Quote Originally Posted by blue wonder View Post
    tony, what's it made out of? ss, alum??? i've been running a 3 gallon jaz tank for years; don't think it weighs more than a pound or two...
    B1 Racing cs19's Avatar
    dont run anything less than a 2 gallon tank IMO.
    San Diego, CA
    I run the small imco. Its a 2.5 gallon with an ice tube that takes away space from the fuel capacity but adds weight from the cap and tube inside, and I just about never use the ice tube. Except in really hot weather. One pass at firebird uses noticeably more fuel than at Ming, considering the longer drive to the out ramp. Truly a 2.5 or 2 gallon tank would be cool. They don't weigh much especially the spun aluminum IMCO ones.
    I think Mudpumper is pretty close on the bottle about 3/4 of a gallon.
    Boat 405.
    yeah i have the same tank also...gonna sell it though, i think the plastic jaz ones are lighter...was just hoping to put the smallest one i can
