turbo wogs project - Page 58
Page 58 of 58 FirstFirst ... 8 48 55 56 57 58
Results 799 to 805 of 805
turbo wogs project
  1. #799
    sacramento
    Default puke tank & bracket build
    got a used puke tank & pulled the dent out at the fitting on the side & polished it . hand built a bracket & got the valve cover bling. it was kinda tuff as the carb sits a little crooked between the turbo set-up but the bracket & tank sits perfect.
ID:	1035825   Click image for larger version.
ID:	1035827   Click image for larger version.
ID:	1035829   Click image for larger version.
ID:	1035831   Click image for larger version.
ID:	1035835   Click image for larger version.
ID:	1035837   Click image for larger version.
ID:	1035839   Click image for larger version.
ID:	1035841   Click image for larger version.
ID:	1035845   Click image for larger version.
ID:	1035847   Click image for larger version.
    sacramento
    Default crank trigger custom bracket build
    i was getting kick back,breaking starters etc.. i found out that when the timing went into start retard the rotor was in between 2 terminals. so i ground open a cap and phased my distributor and built a bracket so i can actually get to the timing in the boat . the brackets are designed to mount on the bottom or in a way i couldn't get to it to change the timing originally. i also put a bigger style cap on with a cap adapter and a nice good starter. i put all stainless hardware on after bracket was finished.
ID:	1035851   Click image for larger version.
ID:	1035853   Click image for larger version.
ID:	1035855   Click image for larger version.
ID:	1035857   Click image for larger version.
ID:	1035861   Click image for larger version.
ID:	1035863   Click image for larger version.
ID:	1035865   Click image for larger version.
ID:	1035867   Click image for larger version.
ID:	1035871   Click image for larger version.
ID:	1035873   Click image for larger version.
ID:	1035875   Click image for larger version.
  4. #801
    sacramento
    Default lifter & pushrod mod
    i noticed i had some extra valve lash of like .045 or so on a couple rockers. the push rods were getting galled up. i had to grind a tiny notch which is normal in some cases as i did read about it and the engine shop verified i needed to get a little more oil up top. also had to have heads clearance more for the fatter pushrods & even still they hit the lifter on the sides and had to do a little grinding.clearancing on some of the push rods.pushrods are super thick!
ID:	1035879   Click image for larger version.
ID:	1035881   Click image for larger version.
ID:	1035883   Click image for larger version.
ID:	1035885   Click image for larger version.
ID:	1035889   Click image for larger version.
ID:	1035891   Click image for larger version.
ID:	1035893   Click image for larger version.
ID:	1035895   Click image for larger version.
ID:	1035899   Click image for larger version.
ID:	1035901   Click image for larger version.
    sacramento
    Default boat interior all cleaned up
    i did honeycomb with fiberglass over for the flooring i dont think it was quite done in these pics.original flooring was 45-47 lbs of wood. this is 20lbs i can get it lighter too as i have a doulbe layer over the tank. it can get some circle cut-outs on the bottom layer .and on the subfloor down by the feet can get some lightning too.
ID:	1035905   Click image for larger version.
ID:	1035907   Click image for larger version.
  7. #803
    sacramento
    Default had to do some trailer repair.
    trailer broke in half in the back thru the light cutout. i cut old reinforcement brace off and added a much longer one. longer than the cutout for the light so it wont be weak. added some flat stock on the bottom too. seen the crack starting on the drivers side so wanted to fix/weld before i put new bunk boards & carpet on. also added 4 more braces all on the beam before the back, to help support the engine weight .
ID:	1035929   Click image for larger version.
ID:	1035931   Click image for larger version.
ID:	1035933   Click image for larger version.
ID:	1035935   Click image for larger version.
ID:	1035939   Click image for larger version.
ID:	1035941   Click image for larger version.
ID:	1035943   Click image for larger version.
ID:	1035945   Click image for larger version.
ID:	1035949   Click image for larger version.
ID:	1035951   Click image for larger version.
ID:	1035953   Click image for larger version.
ID:	1035955   Click image for larger version.
ID:	1035959   Click image for larger version.
ID:	1035961   Click image for larger version.
ID:	1035963   Click image for larger version.
ID:	1035965   Click image for larger version.
  8. #804
    sacramento
    Default turbos ate some stainless steel
    carburator accelerator pump checkvalve needle got bounce between the turbos....been wanting to upgrade.......converting from cast 72mm impellers, 2.5" output to 78mm billet cnc impellers, 3" output ......also had my first actual catastophy...been detonating due to extra hp/heat. been running straight 110 octane and was at 24* timing when she lost a rod. all the rod bearings were smashed out.intercooler can't keep up at the higher boost. 13 psi was il but 16 killed the motor. found out that i have stainless steel cores
ID:	1035971   Click image for larger version.
ID:	1035973   Click image for larger version.
ID:	1035975   Click image for larger version.
ID:	1035977   Click image for larger version.
  9. #805
    okie, lake Texoma
    Wondered how this deal was doing--- sorry for the failure. Rebuild---new larger turbos and add C-16 to the mix and you will be golden. Probably get away with adding some timing too. The C-16 is designed for high intake temps(no cooler) and high boost.
    H8-2-W8
    [email protected] first pass
