Mr. GPS speedo
Results 1 to 7 of 7
Mr. GPS speedo
    Douglas, MA
    Default Mr. GPS speedo
    I just installed my GPS speedo, and now I am pissed I don't get to try it out until spring
    There are some really neat things about this...the face is customizable (though when viewed at 6" you can see some pixilation), it displays max speed, and the digital readout keeps going after you pegged the needle. Does 0 to 60 times and some other cool stuff. Also has a hot start feature that acquires the satellite really quickly. Price was good too. The only downside is they are really thin and use a spin ring rather than the standard long studs...soo...if you want to use a trim ring, you have to drill and tap that, and mount the gauge to the ring and the ring to the dash.
    Chandler, AZ
    I used that company for all my gauges in my boat. The gps speedo works great. You should be happy. Btw looks good
    Dan
    sacramento
    how about # or link . couldn't find it on google. thanks,turbo wog. they look like speed hut gauges!?
    that dash looks like the space shuttle.
    S CP
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Quote Originally Posted by turbo wog View Post
    I have a Speedhut GPS speedo. It looks exactly the same. Probably is. I love mine. Pretty quick to respond, the quick start function is nice, lots of features. 0-60 by time and distance, 1/4 mile, top speed. Dead on when compared to a hand held Garmin. Only problem for most will be its shallow depth and ring for tightening. I have an alum. dash cap so i was able to cut the dash itself to accomidate the ring and cinch it up against the back of the cap. Go to speedhut.com Many customizable faceplates and colors. Great price, about half the cost of most i've seen.
    sacramento
    Quote Originally Posted by mrjoshua View Post
    thanks for the info
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    hook up to the boat, turn on the key, have your buddy pull you down the highway
    or just use a camera.
