speed coatings
Results 1 to 14 of 15
speed coatings
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    Default speed coatings
    What product to use? Speed coat 49 by Wearlon or Lubribond drygraphite? And what about "dimpling"?
    get blown or get blown away
    Feb 2009
    MANTECA
    Sep 2008
    sacramento
    Ya that's 1 I was refering to
    LaGrange GA
    I was thinking that the Tractor Supply stuff was the ticket??
    EZ-Slide Graphite Based Coating, 1 qt. - 212004299 | Tractor Supply Company
    El Cajon , Ca
    There is also this one SLIP Plate®
    Dec 2010
    Alabama
    What part of the hull bottom should be painted with the low friction paint?
    So I've been told that flat black paint works just as good or better. Lightly sanded.
    S CP
    Quote Originally Posted by 77GT View Post
    Depending on the boat you can do as much as I did or you can just do the center and 1 lifting strake out on each side of the pump, that's where the boat will be running at speed.
    Since we detailed the entire area, we painted it.
    S CP
    Glendale Arizona
    Quote Originally Posted by Marcsrollin View Post
    Done one with the high dollar stuff and one with $7 per can (enough to do the job). For my money slip plate graphite spray is as good as anything else out there and way cheaper. Nice and convenient for touchups too. Toss a can in your tool box and hit it when needed.
    Also done an entire bottom area like Jon's and another just covering the area that was worked. IMO you won't get any gains from doing the entire bottom with slip plate or any other graphite spray. Like Jon said, just spray the area that was worked.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    S CP
    Thats what i used, then lightly sanded a cross patern. I wasnt impressed how quickly the speedcoat we used the first time wore off after only 1 season of use. The flat black paint is still looking like it was the day i put it on. Now as far as if one works better than the other, I dont know....
    The guy who helped me on the bottom of my boat won 9 class championships over 12 years, Ron said the paint worked better on his gullwing.
    S CP
    Tempe/Big River
    S CP
    whats he think about crackle paint?
    Quote Originally Posted by white tortilla View Post
    Is that the time he spent a few hrs stripping the bottom of his boat at a race?
    S CP
    Tempe/Big River
    S CP
    i am too young to remember the details for sure i just remember some situation similar to what you described
