driveline question
Results 1 to 14 of 33
driveline question
    sacramento
    Default driveline question
    do i need to replace the whole thing? what is heavier duty ? is it needed or will awsome 4x4 u joints of some sort work with this. i believe it is @ 8"-8 3/8" long .going for @1500+hp . thanks
ID:	142133   Click image for larger version.
ID:	142134   Click image for larger version.
    Shell Knob, MO
    I would suggest replacing that old Rockwell driveline with a modern Spicer 1310 or 1350 driveline and a flywheel button. Either size will handle the job. If you get the U-Joints without the zerk, they are stronger.
    Duane HTP
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    Wog go to Sac driveline for those u-joints there not far from you 704 Houston st. west sac. There Awesome very reasonable and quick to.
    sacramento
    Duane HTP
    do you have any pics of the two & what makes them better? alloy ,size of u joint, thicker, design? what are the rating on the drivelines. could i also get a picture of the flywheel button? would you also be able to get me the $$ on each of those here or p.m., whatever the protocall is. i posted @ 1500 hp + , i actually want to put the 200-500 shot of nos on that too.. thanks p.s. the lenght is important please let me know on both as well.
    sacramento
    Quote Originally Posted by bwurst1 View Post
    thanks Ben, i know where they are, used them for the van & the tractor stuff.
    San Diego, CA
    Spicer 1350.
    Boat 405.
    X's 2 on the 1350 for your application heres a link and a couple images from us that may help Tom
    Jet Boat Performance, Drive Lines
    1310 Drive line, this is the most common modern replacement H-bar drive line for jet boats. The overall length measures 7 1/2", the round register on the flang measures 2 3/8" and the rectangular bolt pattern measures 2" x 2 3/8"
    Heavy Duty 1350 Drive Line, The overall length measures approximatley 8", the round register on the flang measures 2 3/4" and the rectangular bolt pattern measures 2 3/8" x 2 7/8".
    sacramento
    thanks guys , tom i pm'ed ya about some needed info .adapter flange exact thickness for bbc & exact length of the 1350 for bbc to jg berkly .i have a 30 gal tank in the vee with no way to relocate it & very little wiggle room from the front pully to the tank. thanks
    Quote Originally Posted by turbo wog View Post
    I'll have a measurement for you tommorow , to give food for thought I'm remembering 9" OAL on the 1350 , 81/2" on the 1310 (including PTO) Tom
    sacramento
    thanks tom . i'm hoping the 1350 will fit.
    okie, lake Texoma
    Turbo wog, this is what I use. Its the 1350 series spicer joints that arent crossdrilled . I exploded one with the smaller 1310 joints. It was a bad deal took out the drive line cover as well as the intake valves and a few other things. I had Drivetrain Specialties in OKC build this one and balance it. They recommended that i have it rebalanced any time I have the joints replaced. I have the joints replaced every yr. My engine is exactly in line with my pump. If this deal ever blows the next step up would have to be a Lenco shaft.
ID:	142269   Click image for larger version.
    H8-2-W8
    [email protected] first pass
    sacramento
    how much hp were you running at the time & did it break right after launch or in the middle of a hot pass? was there a chance the joints were getting loose when it happened or was it all fresh? were they the solid or greasable u-joints at the time. do you have to regrease the 1350 within the year?
    okie, lake Texoma
    They were the 1310 joints and werent crossdrilled and they were put in at the first of the yr. It was about mid summer. The grease should last for the yr. You have to disassemble to grease them so I just have new joints put in at that time.
    It was with my old draw through system and a 325 shot of nos. It was at the top end of the pass. I was running 115+ in my old youngblood TX20.
    H8-2-W8
    Placentia, CA
    Paulie, that 1350 from Tom looks badass, I'd move the motor if I had too, to use it!
    steveo143 AKA DiMarco 21 II
