13.5to 1
Results 1 to 14 of 35
13.5to 1
    Senior Member milkmoney's Avatar
    vegas
    Default 13.5to 1
    lets get some real answers. the boat i just purchased has 13.5to1 and the guy i bought it from said he was told by people in his area that he could run 100 octane unleaded,(racing fuel @ pump. and worst case if he get only get pump fuel he could run 91 with lucas octane boost, one of my threads, everybody said to run 110 or better, what do you guys think, thanks
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Quote Originally Posted by milkmoney View Post
    I think I'd talk to Glen since he knows a lot about that boat.
    vegas
    going to call him monday for sure..
    Senior Member tx-19's Avatar
    wittmann,az
    with having cast heads and big compression you need to run 11o.it is as easy to get as pump gas.parker oil carries it at the pump 11o sunoco race fuel.the only bad thing is they close at 6 pm and closed on sunday.so fill your boat up and some gas jugs.i think they will be open every day for the holidays
    vegas
    Quote Originally Posted by tx-19 View Post
    i will get some jugs this week, need to go to one local motorcycle shop i guess to get those.any other ideas where to get them..
    wittmann,az
    sometimes the local speed shop carries them or wal-mart carries the red 5 gallon jugs.
    that's what i use they're alot easier to lug around at the lake , plus you don't have to take a funnel
    I'm looking to buy some metal cans, busby said the plastic ones allow your fuel to loose octaine quicker. BTW nice looking squirt boat!
    vegas
    thanks h20, metal, they still make them, wouldnt they be heavy..how big can you get..?
    So Cal
    not octane ... but light hydrocarbons which changes the flash point ... I know it is a bit technical but that's what you loose in reality
    the plastic cans are porous and are not good for long time storage. They are good for a week or so. Storing it in a steel container will keep it good for about a year if you seal it back up.
    Buy yourself a 30 gallon drum the first time and then just refill it so it's easy to move in your truck and store in your garage.
    13.5:1 needs 110, IMO.
    Nice ride btw milkmoney. Good find.
    vegas
    Quote Originally Posted by BUSBY View Post
    great info,, the problem is i do not have a garage right now, living in a condo.. i will have to figure out something,,thanks busby..
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Get the plastic ones and make sure you use up the gas, then store them on your patio or balcony until things change. You're only going to get about 30 feet per gallon anyway so it'll go fast. The gas, that is. LMAO
    Senior Member Mojave85's Avatar
    Boise, Idaho
    Default Photos
    Where are the pictures?
    Cas
    Cas is offline
    this is a pic of the metal ones I've been using for 30+ yrs.
    the first pair I had got sold with my old Jeep in 1982 when it would cost about $5.00 to fill
    Northern Tool carries them if you want to order online-
    http://www.northerntool.com/webapp/w...3366_200323366
    around here, Home Depot, Lowes, and a few other stores carry them.
