Hand hole cover
Results 1 to 13 of 13
Hand hole cover
    Senior Member 19ftDana's Avatar
    Jul 2011
    Default Hand hole cover
    So im finding out my hand hole cover doesnt come all the way out of the transom.. Theres about a half inch that doesnt clear the out side of the transom.. Anyone else ever run into this problem? Or any pics of this same issue..
    San Diego, CA
    Quote Originally Posted by 19ftDana View Post
    Happens all the time. Either build transom plates around it or box around it
    Boat 405.
    San Diego, CA
    Boat 405.
    Or get a P.P.P. flat top and go with alittle more cut out at the top of the pump at the transom. Kinda depends on the transom adapter or plate you are going to use to seal the pump up. M
    Nice job widow maker! M
    Jul 2011
    thanks widow... If u dont mind can u post a couple more pics of diff angles when u get a chance.. I deff got a couple ideas from that.. Thanks again
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    Here's a couple.
    The box that goes around the handhole cover can be machined from a block or tig welded together from aluminum plate.
    Or if you don't care about having access you can just make a small plate that goes across the top of the handhole cover to seal it off, rendering it inoperable.
    Culver City, Ca
    one more view. This time from the inside.
    Senior Member 76 Hondo's Avatar
    Aug 2010
    Mission Viejo/Lost Lake
    This is a shot of my set-up
    Bonus points for IDing pump.....
    California
    Quote Originally Posted by 76 Hondo View Post
    looks like Bayjet
    Aug 2010
    looks like Bayjet
    Damn, winner,Bayjet on a Berkley intake, internals Berk. with an inducer DPS,droop and Berk. noozle/gate
    California
    Thats a beutiful looking set-up, i dig the plates
    Aug 2010
    Thanks, I watch the restoration you guys did on the T-Deck came out nice,bet the owner is thrilled.
    My Hondo was set-up to go circle racing originally, hence the plates and drop thru fin.
