quick prime a jet question
Results 1 to 6 of 6
    Chandler, AZ
    Default quick prime a jet question
    I am about ready to install a prime a jet. The directions say to measure back 2 inches and drill. I am running a new dominator bowl for a 9.5" impeller. The bowl is a lot thicker than a stock berkley bowl. On a berk bowl it would go into the thin part of the bowl, and on the new one it would go into the thick part. Do i measure farther back, or go at the 2" like it says?
    Dan
    Okmulgee Okla.
    I would say go with the directions. All your doing is bleading air from the bowl. Just dont drill into anything but the bowl.
    well the block is GM any ways
    IS UNDER FIRE
    Recomend using a drill stop , a tiny drill for "pilot" (.125) coated with heavy grease and 2" to 2 1/4 from the bowl to suction connection Tom
    Shell Knob, MO
    You can put them at 2" or you can put them back just a little further on that thick registered bowl. It makes no difference. It will bleed the air off either way. I feel that to put the hole just behind the register gets rid of a little more air. Just don't go back far enough to hit a bowl vein with the hole.
    Duane HTP
    Chandler, AZ
    Thanks guys.
    Surprise, AZ
    Measure twice, drill once.
