ratchet works great!!!
    Aug 2009
    Default ratchet works great!!!
ID:	143603ive been lurking for way too long.so here i am.myself and a couple buddies took our boats(tx19,cheyenne,sagaro) out today....new years eve...in iowa...48 degrees..of course,the grimlens were along for the ride.1st,forward revers cable came loose..stuck n reverse..argh!!pulled out and fixed.back out.and she is a little flat on the face at the hit of the throttle.but then runs pretty hard...5200 is all ..ever.i think that the carbs arent seeing complete full throttle...ever..could my old foot pedal be limiting the cable travel length??therfore not achieving full throttle and therefore not going past 5200..oh yaeh theyre 10 year old holley 750 double pumpers.532 ford full roller 10.5 cr diamod pistons eagle h beams and eagle crank eddie cj heads t ram, all msd ign.a cut ss imp,inducer ,droop ,mpd baccut shoe,40 lbs top and bottom suction housing pressure.....any way...it died at 85.and the new ratchet works grrrreat!!!!!thanx duane!!!!!!!!!!!.....pics and video soon
    Aug 2009
    Default video new years eve 2011...iowa
    Aug 2009
    Aug 2009
