Spectra Fiberglass Tanks ?
Results 1 to 13 of 13
    Bullhead City, AZ
    Default Spectra Fiberglass Tanks ?
    Does anyone know, how many gallons does the Spectra 20 stack type fiberglass tanks hold? The measurements for the tanks are: 7'.1" long 16" tall.
    Thank you & Happy New Year
    Jim
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Quote Originally Posted by Squirtin Thunder View Post
    Jim
    Just did a pair of these on both a Spectra and a Cambell (nasty ass job) I'm thinkin 30 gallons ...
    Bullhead City, AZ
    Did you replace them with Aluminum or just clean them out and reglass them in ?
    Jim & Amanda Rich
    CJ 72 & 53c
    Senior Member Sanger-Spectra's Avatar
    May 2010
    I had IMCO make new ones for me, took the the glass tanks to them as a template, thenew tanks are marked as 29 gallons.
Name:	Right rear Tank Mount.jpg
    Dallas, TX
    You do not want to reuse those glass tanks if you are using pump gas. The ethanol in our gas will dissolve the resin and cause you all kinds of problems.
    Bullhead City, AZ
    Quote Originally Posted by Sanger-Spectra View Post
    Thank you thoughs look nice!
    I was thinking of templet for new ones. I was hoping for 40gal. but we can add a lil length and get what we need.
    Jim & Amanda Rich
    CJ 72 & 53c
    Bullhead City, AZ
    Is there anything that can be done to seal them from the fuel ? Because these tanks are still good and knew ones are crazy $$$ wise !
    Jim & Amanda Rich
    CJ 72 & 53c
    Cas
    Cas is offline
    Angry American Cas's Avatar
    You can use this calculator to get the actual capacity- http://www.greertank.com/tankcalc.htm
    A
    lso, check with a local radiator shop to see if they can coat the inside of the tanks. I had one done about 15 yrs ago but it was a 10 gal stationary tank for a home generator that as far as I know is still being used.
    Re-member Willie B's Avatar
    Lake Oroville Ca./N. Hollywood Ca.
    Default ...Imco...
    ...I replaced mine in my Spectra 24...with Imcos... ...100% satisfied... ...I did the install which was time consuming and a bit of a task but well worth it......
    Honestly wouldn't waste time with the old FG tanks , for the aggravation and saftey factors alone not to mention what it would take to try to make them work (cleaning and coating etc) this particular boat had no less than 10 gallons of varnishy fuel in the bilge and tank voids , new tanks like these we're installing were about 1K and made dead nuts to our measurements Tom
    ya don't want one of these for sure ....
    Large Member edog's Avatar
    Riverside, Ca
    To figure out gallons. In inches, use L x W x H /231. it might tough to get accurate since the tanks are not perfectly square.
    Bullhead City, AZ
    Honestly wouldn't waste time with the old FG tanks , ya don't want one of these for sure ....
    All right I guess it is going to get the smaller 20gal Skyline Aluminums I have.
    Jim & Amanda Rich
    CJ 72 & 53c
    Quote Originally Posted by edog View Post
    ...For the width measure the tank from top to bottom on one side of the tank... ...Whatever the center of that dimension is should be fairley accurate for your calculations,...if both ends of the tank are the same...
