Need a picture of a set back pump transom plate
Results 1 to 14 of 14
    Oct 2011
    Default Need a picture of a set back pump transom plate
    Mounting a Berk set back in my Alaska work skiff. I'm doing all the fab work here in CA before shipping everything up to AK for the install. It appears that making the 1/4" plate fit around the pump itself is pretty straight forward, I'm wondering however, how you seal up the area below where the plate mates up with the intake flange. Do you cut two small pieces of alum to fit into each side under the intake flange or what? Anyone have any pics?
    Quote Originally Posted by 5akman View Post
    No two of these are exactly the same , depending on the hull they are typically made in two halves but can sometimes be made in one piece , suggest you mock them up with card board and carefull measurment first and get the edges that meet the jet suction body as close as possible , 100% silicone is typically used to seal them call if you have questions Tom
    Dallas, TX
    Here is another pic where you might can see the bottom a little better
    Senior Member zacho!'s Avatar
    tucson, Arizona
    Much like Tom said, I made a template. But I used a 1/4" masonite. After the perfect scribe, I used a jigsaw with a fine tooth blade to cut the aluminum plate. I continually cut into a bar of soap to keep the aluminum from packing itself in between the blade's teeth. Might be ghetto but it works very well.
    Damm! my pile looks super ghetto back then!
    Quote Originally Posted by zacho! View Post
    Nice ! good tip on the soap !
    Oct 2011
    I hadn't thought of splitting the plate vertically. I think I'll go that route as I can then address the area under the intake without having to deal with some little pieces of alum.
    Apr 2011
    Tulsa,OK.
    I saw a post that some one used a welding rod and bent it to form around the pump.
    Senior Member redlightrobert's Avatar
    i like using the plastic for - sale type signs from homo deep, or dollar store to make the templates. cuts easy with scissors,retains its form, and when you get it wet it does not swell or anything,
    BOOBS; once you have seen one, you want to see em' all!
    the real honcho bagged97taco's Avatar
    tucson az
    I built some for my buddies 21 daytona split them down the middle. Pics are raw aluminum, he had the powdercoated to match hull. Just take your time on the templates and cut slow. I also used a rotor zip with metal cutting tip for the little areas.
ID:	144148   Click image for larger version.
ID:	144149   Click image for larger version.
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Here's a few shot's of the one's I just did on the Syndicate!
ID:	144157   Click image for larger version.
ID:	144158   Click image for larger version.
ID:	144159   Click image for larger version.
    Oct 2011
    Great pics guys. Wow, working around the Dominator housing looks like fun!
    tucson az
    It was fun! Not too bad for my first time and being a vdrive guy and all..
    seattle
    Default transom plate fab
    Skagen Boats » Forums » Performance Boaters » progress at the shop
    couple of good pics here...page three and five...
    for some reason link don't work...
    while on link...click the forums tab...then performance boaters...then progress at the shop...page 3 and 5
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Can't see all of it
    QE 439 Twin Turbo
