key way in steering rack
Results 1 to 7 of 7
    Senior Member lupo1904's Avatar
    Feb 2011
    Default key way in steering rack
    got a new 4'' exstension but i cant get the key out of the key way, is there a special tool or something i am missing? this is being a bitch,all this for 4''
    Quote Originally Posted by lupo1904 View Post
    If I understand correctly the half moon key is stuck in the 3/4 tapered rack shaft ? if so clamp a really good pair of vice grips very tightly on it (the woodruff key) and tap upward on the end of the Vice grips to "ask" the key to come out Tom
    Feb 2011
    so i need to pull it out of the dash board? why cant they make this easier to do? #1 take off steering wheel #2pull off adapter flange #3 remove 3/4 nut #4 pull four bolts from rack #5remove 3 bolts going through dash #6 bound out key #7 put key back in with new 4'' exstension #8 put all this shit back together. fuk my life, what a pain
    Just trying to visualize , if this is a Morse or teleflex once the actual steering wheel is off the adaptor hub comes off by removing a large nut ,leaving a Hub once the hub is pulled from the shaft the shaft should be protruding from the dash with the key in it ? if the key is stuck go with the vice grips then clean up or replace the key install the longer hub and reinstall the steering whell viola ! no need to pull the help that I could see? Tom
    Feb 2011
    Thanks tom ill figure it out when i get off work when i put the new rack in it gave me the same problem, i just need to remember how i did it last time
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Dykes. Grab it with dykes and rotate it up, they have a built in lever.
    QE 439 Twin Turbo
    Feb 2011
    got it handeled thanks guys
