suction housing
suction housing
    OU812 Member mel87901's Avatar
    Nov 2011
    Default suction housing
    Anyone tell me the easiest way to remove the ware ring on a JG suction housing,Is there a tool for this?I dont want to tear it up,Any Help.Thanx
    San Diego, CA
    Quote Originally Posted by mel87901 View Post
    heat.
    Boat 405.
    We use an acetelyn torch with rosebud but you can do it with a propane bottle or mapgas torch , pass it round and round the WR till the liner starts to "craze" and carefully pry the WR out while the liner is still hot, suggest a well ventilated area as the fumes from the liner are noxious
    call if you need help Tom
    Nov 2011
    Thanx for that info,I put a torch to it yesterday like i was told and that wear ring came right out with out a problem.Thanx for awesome info.Mel
