drivetrain locked solid
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 51
    Nov 2011
    Default drivetrain locked solid
    could it be a wear ring problem?
    i was test driving my day cruiser today, ran it for about 10 minutes, when i turned around and headed back it lost 1000 rpms and bogged, i let out of it and it stalled, when i hit the key it was locked up, but had good oil pressure and temperature, forward to getting home
    i pulled the plugs to check for water, it was dry, checked the oil, no water and is full, but it would turn over but still has drag, pulled the bowl and still the same results, ten i started thinking about the wear ring, i tookit apart and noticed that the rubber between the wear ring and pump housing was rubbing the impeller(see pic), but could this cause it to bog and lock solid, tomorrow im going to see if it will crank as is, it has no marks on the impeller or wear ring, only where the rubber is hanging out a little. i have a hard time believing it is the motor.
    can this be my problem?m if not what can be?
    Shell Knob, MO
    Nope, that it ain't it! Check your motor. Sounds like a spun bearing.
    Duane HTP
    Mar 2010
    Clarksville, TN
    Sounds like a engine problem. Might pull the plugs and try turnin it over. Might as well unhook the driveline also.
    Nov 2011
    it was still binding with the plugs removed....i meant to add that i did turn it over as is, so im going tio put plugs in it tomorrow and try to start it, would a seized bearing free up over time? i can turn it over freely without straining the starter without the plugs in it now
    also what may be related leading me to believe it is the front pump bearing is a loud shuddering vibration/noise while idling in the water, i only took the boat out twice and heard it both times in the idle zone. but never heard it on the trailer. it would go away with a little throttle.
    Quote Originally Posted by SimplyOrange View Post
    Once the Jet is eliminated as a potential issue and if it wasn't hydro locked , I wouldn't spend much more time replacing plugs etc and trying to run it , I would pull the engine and pull the pan , a "piggy backed" or "lapped" rod bearing insert for example could show acceptable oil pressure , if there is actually a lower end failure every running revolution of the engine can potentially cause further damage to the crank Tom
    BTW what engine?
    Nov 2011
    BTW what engine?
    bbc 454, if i put the plugs in and it doesnt turn over then i am going to flip it over and pull the pan, it didnt hydrolock, it has no water in the cylinders and even after pulling the plugs it wouldnt turn over, it only turned over after removing the impeller, but there was elapsed time for something to cool down and let loose.
    Disconnect the driveline and see what happens
    Shell Knob, MO
    Siezed or stacked Bearings will let it turn over again after it cools off. Like others have said, pull the pan and do not start it again. Smell the oil. Usually the oil in an engine that has had bearing filure has a slight burnt smell to it.
    Duane HTP
    Like said ,often times a "siezed" (spun rods or mains) engine will somtimes crank and even get a re-lite after cool down for a short time then sieze again , re the jet frt thrust bearing if seen these blued, dehydrated and the individual Balls split but still turn likley is the suction housing paint around the bearing would be blistered along with other symtoms if the thrust bearing had siezed
    Heres the result of "continued operation" after the onset of an isolated bearing failure
    Nov 2011
    ok, im going to go ahaead and pull the motor and pan then, i cant see the thrust bearing without doing it anyways with my 3 point system. i hope its not the motor but if it is, im fixing it with HP
    PASO ROBLES CA cougar63's Avatar
    PASO ROBLES
    Jesus Tom ,who's motor is that? I cleaned up the SST and looks pretty good. And like the others said,dont waste your time,pull the motor.
    B1 Racing cs19's Avatar
    Disconnect the driveline if there is good access. If the bell housing covers the driveline it's probably easier to r&r the engine. Hard to get those 4 bolts through that tiny inspection cover.
    B1Racing.net
    Investigate that wear ring insulator also. It's sticking out pretty good. Might be able to just trim
    it if everything looks ok.
    B1Racing.net
    Thats the Attitude (more HP)
    Quote Originally Posted by cougar63 View Post
    Greg thats an extreme example of a failure from my other work , but all to often what starts as a "knock" can end up as a rod thru the block if not addressed
