what seal needs to be replaced if...
Results 1 to 2 of 2
    Sep 2009
    Chicago, IL
    Default what seal needs to be replaced if...
    when I fill my bowl with oil, it leaks out the intake grate?
    What do I need to order to fix it? Does the Impeller need to come out?
    Thanks.
    Quote Originally Posted by PowerAddict View Post
    Thanks.
    It could be the bowl seal (fowled or worn) It also could be the shaft and or the bowl bushings are worn or even a shaft bowl plug allowing leakage , and worse case scenario it could have a hairline crack in the circular dished area that surrounds the shaft bushing boss and oil reservoir behind the impeller, quick way to determine any of this except the bowl plug is to simply pull the bowl , the bowl plug can be seen thru the nozzle ,call if you need help Tom
    PS to simply replace the seal would not require Impeller removal
