"Glass" Tanks
Results 1 to 5 of 5
"Glass" Tanks
    Default "Glass" Tanks
    Thought we'd put this out there for those who have fiberglass tanks or are considering a boat with them, Like alot of marine repair shops and vintage boat owners for the past several years we (like others) have been seeing leaking and seeping and deteriorating fiberglass fuel cells in some of the mid 70's boat equipt with Fiberglass tanks As most know these tanks are profoundly affected by modern fuels and can deteriorate from the inside out over time , Over and above the obvious danger of fractures , leaks to bilge fumes etc we've also seen slimy brown discolaration and residue in fuel , fuel feed and fuel filter issues and general runability/carb issues. But this is the result of one of the worst the so far . These pics are from a 429 BBF from 74 Cambell V-drive we have in process , It initially came in for fuel tank replacement/upgrade with an "oh by the way it also hasn't been running well complaint too!" Have replaced the Glass tanks and all fuel related plumbing and decided to run compression and cylinder leak down , finding two cylinders with "0" compression and bent push rods it was time for tear down , heres what we found today, this engine will have to come completley down ...
    black syrupy residue in the cylinders
    Sticky residue in the intake ports
    Black goo in an example cylinder
    intake valves stuck open from molasses like residue on stems
    typical valve, stem residue
    WOW caught it in the nick of time..... almost
    sacramento
    thanks for the info! my dad always has carb issues & has a tank in the front. i believe it is a glass one! i will notify him. thanks again !
    Jun 2011
    spokane, wa
    Wow, that is nasty!!! Thanks for the info Tommy!!!
    Quote Originally Posted by blownboosted View Post
    I had something similar happen years back on a fresh rebuild with old varnishy fuel, lit the motor for a micro second , went for a re-lite the next day to do break-in and all the pushrods bent (vavles stuck from varnish) , hard lesson about sh*tty fuel, Cant wait to see the piston rings on this one !
