mallory dist
Results 1 to 2 of 2
mallory dist
    Senior Member hpltree's Avatar
    Sep 2011
    ventura , ca
    Default mallory dist
    i have a mallory single point marine dist.. and was thinking? do i need to run the ballast resister like some of them or if i run an internal resisted coil am i ok ? thanks robbie
    Spiral out MikeF's Avatar
    Quote Originally Posted by hpltree View Post
    Either, or.
    Preferrably the external resistor cause you are then able to run a 12v lead straight to the coil for startup purposes only.
    To add.....this 12v source should come from the starter solenoid....so it is only "hot" when the starter is engaged.
