alternator bracket for a 4pt motor mount rail kit
Results 1 to 7 of 7
    Mar 2011
    Default alternator bracket for a 4pt motor mount rail kit
    The typical spot for the alternator wont work any more with the 4ptmotor rail kit, compared to 3pt system. What are my options ? Where to mount? Special bracket??
    pics might help as well.
    Thanks much for your assistance.
    Aug 2010
    most of the time they're mounted to the front plate with a bolt and spacer, and then a little heim joint and turnbuckle is used to keep tension.
    The Man cordog009's Avatar
    East Texas
    I've got one of Duanes from HTP on mine, mounts on the passenger head and has the optional tensioning arm. High quality piece for sure. Check out his site and see if it might work for you.
    1984 Youngblood TX-19 SOLD
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Scroll down after the headers.....
    Hi-Tech Performance : Other Performance Parts
    Duane made one for me on my last boat and it worked great!
    Senior Member stewvette's Avatar
    Nov 2009
    I used the turnbuckle as well.. went to the upper water pump block-off bolt. with my dampener v pulley setup i was able to bolt the alt. directly to the engine plate.
Name:	ALT MOUNT.jpg
    sacramento
    mine is an over the stringer set-up
ID:	147620   Click image for larger version.
ID:	147621   Click image for larger version.
ID:	147622   Click image for larger version.
