[Question] Anyone run a Precision Jet Drive billet impeller?
Results 1 to 10 of 10
    Feb 2010
    Default Anyone run a Precision Jet Drive billet impeller?
    Hi, I'm about to buy a new impeller for my boat and thinking of trying one of Precision Jet Drives billet aluminum ones. Just wondering if anyone here has run one and can tell me how they compare to an AT or Berkeley of the same cut. I like the idea of a cnc machined from billet impeller for concentricity and balance reasons, but that will not help much if the blade profiles are poor. Anyone with any thoughts or experience?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Is that a 2 piece impeller? You might check.
    QE 439 Twin Turbo
    Las Vegas, NV
    here is another thread about them
    http://www.performanceboats.com/jet-...any-input.html
    i read another thread on here where someone had one come apart and destroy their bowl.
    Although we have never actually sold one , Josh ran one of Kimballs Impellers for sevreral years with close to 600 Hp with good sucess Tom
    Feb 2010
    Thanks everyone for the info and opinions. I am only running about 250hp at low rpm's(it's a diesel) so not to concerned about it coming apart. More interested in how good the blade profiles are and how they load compared to an American Turbine impeller of the same cut? If anyone else has run one keep the opinions coming.
    New Port Richey, FL
    250 HP diesel 3X as much torque? But if it has an alum inpeller now then I guess it's not an issue.
    QE 439 Twin Turbo
    B1 Racing cs19's Avatar
    Out of curiosity what size impeller have you been running with that Diesel?
    B1Racing.net
    Feb 2010
    I've been running a 9 1/2" AT alum impeller. Engine is a 4 cyl. 1.9l vw tdi. Turns the 9 1/2" to 3800rpm.
    CAPTAIN KRYLON
    Jul 2009
    LEWISVILLE TX
    Default tdi
    Quote Originally Posted by shakescreek View Post
    Post a pic or 2 of that thing. Sounds cool.
    Atlanta, Texas, United States
    Your number line up real well with the 9 1/2" AT chart at 3800 RPM this equates to approximately 252 HP and 348 ft lbs of torque. The AT aluminum is probably adequate as evidently it is holding up at present. I don't know where you operate, but if you were ever in salt water, etc, the stainless impeller would be a nice upgrade.
