choosing an impeller
Results 1 to 7 of 7
    Mar 2011
    Default choosing an impeller
    At what point and time do you no when to change the cut on an impellor to go faster??
    And which one do you go to?
    Senior Member zacho!'s Avatar
    tucson, Arizona
    Quote Originally Posted by PBWOOD View Post
    The pros will chime in soon, but it all depends on where your motor makes peak power and an impeller chart.
    Senior Member lupo1904's Avatar
    Feb 2011
    Its not only in the impeller you need bowl work, mine is getting done right now if you want we can go to bosticks house and i can introduce you to him call me
    Shell Knob, MO
    PM me some information about your boat, and I'll help you.
    Duane HTP
    tucson, Arizona
    ^And to add to that, the shoe-rideplate, loader, stuffer... and to make it a little more PITA, the suction housing pressures...
    Senior Member wildstreak's Avatar
    Feb 2009
    East Texas
    I would dyno the motor first. With that info and some boat info you can make an educated selection. you need know how much hp and torque the motor makes, and at what rpm and what type of hull and weight. Any power adders in the future plan?
    Feb 2011
    Did u fix the crack in your block
