Can't get the H bar off the pump shaft
Results 1 to 2 of 2
    Oct 2011
    Default Can't get the H bar off the pump shaft
    I'm tearing down a run out Berk pump. The bearing sounds like its filled with gravel when I spin the shaft. I can't seem to get the H bar/U joint assembly off the shaft. With the condition of the bearing, I'm wondering if the prior owner ran this thing just short of seizing up and the H bar is "hammered" onto the splined part of the shaft. If it comes down to saving one or the other, I'm much more interested in saving the H bar as opposed to the shaft. Any suggestions?
    Quote Originally Posted by 5akman View Post
    Chances are the pump shaft splines are twisted or galled which is very common ,I'm thinkin , unbolt the driveline from the engine,pull the pump the bowl and take the impeller off, remove the woodruff key , packing ears, and remove the bearing cap , carefully push the shaft assy out the front with the driveline attached and use a remove the driveline out of the boat (this will definatley depend on the type driveline and the method could vary) call if you need coaching check your PMs for a number Tom
    PS better plan on double checking engine crank thrust clearance as well as a stuck yoke/Drive line can create problems there ..
