Exhaust manifold question
Results 1 to 3 of 3
    Member Romper Stomper's Avatar
    Dec 2011
    Default Exhaust manifold question
    I finally got around to tearing down my boat ('76 Glastron Carlson CVX-20) and these are the manifolds that it had on it. Are they worth cleaning up and using, or should I look for something else? I'm thinking about using something else only because when I pulled the heads, the cylinders were rusted pretty bad from water sitting in them. Also, do they flow very well?
    Aug 2010
    they'll flow fine. make sure theres no corrosion/holes in em with a pressure test.
    Senior Member kiethco's Avatar
    Oct 2011
    Long Beach, CA
    Yep, Agreed. Those are just short headers. Perfect for your Intimidator. Without doing a bunch of other motor mods, you'll do well with these manifolds.
