[Question] where to find a drive shaft
Results 1 to 14 of 14
    Broke Member monstertahiti78's Avatar
    Feb 2012
    Folsom, CA
    Default where to find a drive shaft
    hey guys i am looking for a drive shaft for my motor. this is my first time doing this so im not even sure exactly what i need. the guy i got the boat from was running a BBC that was a beast and said that his drive shaft was meant for high torque. the motor i have going in it is no slouch so do i need to get something similar? any suggestions of where to start looking?
    thanks,
    nate
    You could save alot of leg work and just call Tom at jbp...or Duane from hi tech on the boards. I am not sure how much hp=beast. Mine is just 1310 u joints. Some of the 1000+ hp guys run 1350's...and maybe others with lower hp do too...I donno. The drive shaft guy I spoke to recently when I lengthened my dl said 1310's were good for quite a bit with a jet because on water the dont get shock loaded like dropping the clutch on asphalt with a big wide set of slicks.
    First off Hi Nate, where do you live ? Then maybe someone in your area can give you the help you need.
    Quote Originally Posted by bob fry View Post
    Ditto, I have some pieces and a length you want would help! M
    The Earth
    Blog Entries
    24
    I have the on the shelf if you need.
    Feb 2012
    Folsom, CA
    thanks for the help guys. i live in the sacramento area. honestly i have no idea what i even need. im totally green when it comes to jet boats. i grew up skiing behind mastercrafts and nautiques but have always loved jets. thought it was about time for one.
    Nate
    The Earth
    Blog Entries
    24
    Quote Originally Posted by monstertahiti78 View Post
    Nate
    Feel free to call Nate and we will figure out what you need. Mike, Rex Marine, 909-592-1000
    sacramento
    i might have a spare driveshaft. not sure what you need but i seen it on my self. what type of boat? is the motor in? . i am in sacramento too. p.m. me if you wanna check it out
    Feb 2012
    Folsom, CA
    Thanks mike. Ill probably be giving you a call in the next few days.
    Nov 2011
    Default Probably these
    Unless you want to move the motor forward....
    Senior Member CP598's Avatar
    Sep 2008
    PM sent...
    Vern
    May 2011
    sumner county TN
    Default driveline
    thanks,
    nate
    Go down to your local spicer dealer and buy the thing no shipping and over the counter parts at most dealers
    Alamogordo NM
    Nate
    you wouldnt happen to have a ski nautique sitting in your driveway thats in the way of you building that jet would you? just found a bbc driveline on local craigslist i think, fifty bucks.
    Feb 2012
    Folsom, CA
    Wish I did. I really miss the ski boat. Did u see it on the sac Craigslist?
