Who sells the best hydraulic diverter pumps for race use on jetboats??
Results 1 to 14 of 31
    Senior Member badbug3's Avatar
    Default Who sells the best hydraulic diverter pumps for race use on jetboats??
    Also wondering if the hydraulic diverter pump pressures, ( and pumps) were the same for recreational type use and for race only use or are there differences between them?
    Bullhead City, AZ
    What I have done is increase the size of my lines and it helps, we tried the smaller ones and it was much slower. So the volum of hyd fluid helped.And that is with the standard Bennett pump.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Have the power run as short as practical to the pump, power relays speeds up the motor and relay actions. I have a fairly long run for the hydraulic lines. Mines works very well, almost to well, it's too fast for racing with out up down stops.
    Senior Member Futs's Avatar
    Orange CA, Big River
    parker pumps. ive been trying to find a supplier for a couple years. The bennett pump will work with relays and -4 lines. its pretty quick.
    Senior Member bp298's Avatar
    LHC
    i've been using the stock p/d bennett deal for a long time. no relays, just wired per instructions. has always worked fine for what i do. it will go from stop to stop in just under 0.7 seconds. there are better pumps, etc.. i've just never had the need for it to move quicker.
    Senior Member slow67's Avatar
    DFW
    What pressures do these pumps typically run at?
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    http://www.performanceboats.com/jet-boats/85651-place-diverter-cylinder-there-under-$100-00-alternative.html
    previous thread on one.
    Jan 2012
    St. Louis, MO
    Quote Originally Posted by slow67 View Post
    I talked with a Bennett rep many years ago, and my recollection is 350 psig, or thereabouts.....
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    The Bennett pumps put up 300-350 PSI. We have been selling them for about 25 years and have not had any problems. The main thing for good performance is to use large enough wiring or better yet use relays.
    Ron
    One less DEALER means more DISCOUNT for you
    B1 Racing cs19's Avatar
    We ran a data logger on a Bennett unit years ago. I remember 325 psi. I think. We've ran other pumps with good results.
    B1Racing.net
    Have sold serviced, installed, and repaired litterally hundreds the Bennet pumps designed and built for Place Diverter with had excellent sucess and very few problems , issue encountered are often related to low available voltage , poor connections , moisture intrusion etc. Very Good product Tom
    what kind of pump is jordon running on his placecraft?
    DFW
    Quote Originally Posted by ATM View Post
    Ron
    Hmmmm seems like it wouldn't be too hard to mount up a hydraulic pump and set it up like a belt-drive fuel pump, might be faster response, and no electrical load (for a race boat).
    Concord, CA
    Default pumps
    You can change the rate of travel by putting in a larger(wider) for slower movement, or smaller(thiner) for quiker movement.
    Jerry
