need this confirmed ASAP
Results 1 to 8 of 8
    Alamogordo NM
    Default need this confirmed ASAP
    is this a "rocky" bbc driveline? Thanks in advance.Name:  5L25Hb5M23K93F63M3c1r4872da7511201670.jpg
    Yes ! Its what we refer to as a "long" rockwell it has a smaller 1310 ujoint than its shorter siblings and can be replaced in most cases with 1310 Spicer and PTO combo , in good shape its worth some $$ Tom
    Alamogordo NM
    Thanks tom, just found it on local craigslist, snatched it up, changing from olds to bbc.
    Default Rocky??
    Isn't that also referred to as an "H" bar drive coupler?......
    Ray
    LOUD BOATS SAVE LIVES
    Ray
    I guess so as well as double carden etc , Rockwells and spicers use variations of the same basic design , that one chance found is "sough after" because the OAL almost exactly equals a 1310 spicer w/pto we just call them Jet drive lines :0
    Oct 2010
    661 So. Cal.
    Semi intentional thread jack......
    What are these things worth if they are still in good shape?
    Quote Originally Posted by SuperJet View Post
    If some one really wants just that DL somewhere north of $150 , it can be replaced/upgraded for about $225 ish Tom
    Oct 2010
    661 So. Cal.
    Ok reason why I ask is because I will be listing my 3 point mount for a bbf and was on the fence about letting the driveline go with it or just trashing it for liability reasons
    Sent from that vibrating thing In your pocket using Tapatalk
