lesson learned
Results 1 to 14 of 14
lesson learned
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default lesson learned
    That my surface was clean enough...guess not. FYI...sealer is rock hard and a pain to sand off!
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Hmm.... I usually try and avoid sharing dumbass stories.
    QE 439 Twin Turbo
    Led
    Led is offline
    Jul 2010
    I just as well make my PB buds, laugh and call me a dumbass too. LOL. At least I didnt tell the story of when I .... LOL
    Led
    Led is offline
    Jul 2010
    Good news is she is pretty in primer again...but primer is $100/gallon and I used over half on the bottom..as of now! I love Jet Boats!
    Well a post showing stuff like that can be helpful to a newbie. Not only to set yourself up to the harassment, but to help someone out. The most important aspect that I noticed was that you stopped once you noticed things weren't right. Just think if you kept laying finish down thinking it would cover over...now that would be a funny nasty mess.
    New Port Richey, FL
    That's odd for this forum. supportive constructive positive. lol
    QE 439 Twin Turbo
    Green Bay Wi,USA
    Many of us make mistakes, I try to follow rather than lead as my budget, or lack of one, lets me see how the others forge thru different issues. The old Hot boat forum was fantastic. I sure learned alot engine building,Info, and jet drive, v-drive etc. Your post is helpful.
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default Damn
    Bummer you should have seen that mess coming thru on the flash coat..... did you use fish eye eliminator in the paint and prepsol to degrease prior to paint?
    The Earth
    Blog Entries
    24
    I could write a novel of these learning how to do shit right.
    I am pre-fect........I have never made a mistake in my life......Riiiiggghhhhtttttt........
    Dec 2010
    Sapulpa ok
    Get after it!!! I have my pen ready !!!
    Led
    Led is offline
    Jul 2010
    i was in a hurry and wiped the entire boat off with degreaser with ONE rag...and another hint...it was a RED rag....I had the intentions of wiping it off again...but started mixing sealer and next thing I know ..... ,
    Really put my first coat on too thick...
    But she is nice and ready for paint tonight, or may spend my valentines day with my valentine..the boat.. and spray it then...LOL
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    Dont feel bad, done a lot of stupid paint mistakes myself. Was painting a friends boat and somehow on the final washdown before we put in the Makeshift booth someone(not saying who) used Carwash soap instead of regular dawn type of soap to wash it. The Carwash soap had a wax additive of somesort in it, OPPS. Fish eyed all over the place even with a Wax and grease remover.
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    What grit was the surface prepped to before you applied the sealer? what brand sealer did you use (Part # please?) also if you used a home compressor, you might want to look into a drier and/or water catch....sealer can be a bitch considering its used as a bridge between a blocked surface and the finish coating (Or base/clear coat application) only time I have personally seen this happen is when the surface was not cleaned or not prepped (Sanded) properly. just my .02
    hope everything has worked out for the better for you today...Happy Valentines day! Muah
