Traded my cabin Cruser for a 79 Tahiti 21 Limited
Results 1 to 12 of 12
    Member DarylP's Avatar
    Jan 2012
    Benton City, Washington, United States
    Default Traded my cabin Cruser for a 79 Tahiti 21 Limited
    Hello all I'm new to the board. Just traded my 79 bayliner Saratoga offshore for a 79 Tahiti 21 foot Limited with a 460 and Berkly pump. Can anyone give me info about this boat? Top Speed and typical problems with it. Owner I got it from had the drive-train rebuild with all receipts.
    Senior Member wolfie's Avatar
    Fantastic trade. Then again, trading a Bayliner for a 6 pack of Natural Light could be considered a good trade, so you did a great job!!!
    Jan 2012
    Quote Originally Posted by wolfie View Post
    Auh come on now!! She was a good boat...
    Jan 2012
    Default So what would be a guess for top speed?
    The 460 has been rebuilt to stock specs. And the pump has also been rebuilt with a new deverter. Last owner was trying to tell me top should be around 60-70. Only thing wrong it under sized Carb. Currently choked by a 650. Should be up around a 750 780 I would think...
    Jan 2012
    Also First jet. Can you run the engine with the boat out of water? Use to putting muffs on stern drive. Can the pump be ran dry?
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    You may see 55 out of her. Dry start is a No No. Take the drive line off if you want to start it.
    Jan 2012
    Quote Originally Posted by jyeager View Post
    Thanks for that info...
    66 HALLETT
    San Jose, CA
    What I would do if u want to start the boat out of water and not take apart the drive line ..... is take a hose and stick it in the end of the pump. Put the boat in reverse so the hose stays put and turn it on. This will wash the pump free from dirt and keep it cool wwhile running. You will also need a second hose to hook to the motor if u run it long.
    ......every one has there own way. Hope this helps
    Jan 2012
    Quote Originally Posted by 66 HALLETT View Post
    Thanks again
    Jan 2012
    Default Reverse Rotation Starter
    Does anyone have a link to a website that has a good price on the reverse rotation starter for my 460?
    Quote Originally Posted by DarylP View Post
    Call Tom at Jet Boat Performance. He'll hook you up.
    Senior Member papaletch4130's Avatar
    Jul 2010
