Motor placement in 18' southwind v bottom - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 20 of 20
  1. #15
    Quote Originally Posted by bbfsouthwind View Post
    And what so you guys consider a "ton of work" I'm no stranger to the labor involved in things like this. I have not flipped the boat yet to do the bottom so I can do whatever needed to the bottom to make the boat work.
    a ton of work may equate to alot of trial and error , lots of test and try, lots of adjustments/combinations and trips to the water a bit of frustration and then who knows you might nail the setup right away
    Senior Member Futs's Avatar
    Orange CA, Big River
    Well lets hope you dont need to find out what a "ton of work" is.......
    Do you have any pictures of this boat we can see? Did you cut the intake all the way through?
    I just did the bottom on mine. I only have a little 325 LS engine in it, But i only did the inner most strakes and started about 3' from the intake opening. They only had a small hook. Left everything else untouched. Boat does'nt do anything weird or has no hop at all. I would start with that.
    Then put it together and see what it does. Why put a ton of work into something that is unknown? Get the set up dialed and then you will figure out if you even need to mess with the bottom more. I always say do one thing at a time so you know what it did.
    Start with just the set back and cleen up the keel and strakes and massage the entry and run it.
    Thats what i would do anyways. seen to many people turn a good running boat into a horriable riding boat too many times.
  4. #17
    Sep 2009
    Ok, I don't mind the trial and error and the adjusting and changing things. That's what this is all about to me, I just need some pointing in the right direction so I don't get too far along on the wrong path lol. I don't have any pictures of the bottom just yet, but the intake opening is cut through the back of the boat.
    Sep 2009
    Also, the pump is setup with a shoe and ride plate. I will get the correct loader when I assemble the pump.
  7. #19
    southwindsal will be back southwindsal's Avatar
    los angeles
    what correct loader would that be??
  8. #20
    Sep 2009
    Well I'm not sure on what type of loader to use as I have not completely finished up the pump yet, I was going to turn to one of the experts to help me make my choice.
