Southwind 18' / Berkeley Question
Results 1 to 7 of 7
    Senior Member Mojave85's Avatar
    Boise, Idaho
    Default Southwind 18' / Berkeley Question
    What is everyones experience with putting a droop snoot on your Berkeley pump on a 18' Southwind? I found a droop for a decent price and am wondering if it helps this setup. Please keep in mind this is going on a project boat for my daughter and I haven't even gotten it wet yet. Trying to plan ahead.
    Senior Member Futs's Avatar
    Orange CA, Big River
    should work good with stock power. You will need a split bowl for it. Most came with a jc pump..the best thing for it would be a place diverter.
    Boise, Idaho
    The suction housing is a stock jc but the bowl is a jg. Have no idea what it's going to do but thought I may pick up this droop if there is a chance it will help the performance of the boat. If it is a waste of time I won't get it.
    Senior Member wolfie's Avatar
    If it's a good price, pick it up. If it doesn't work out, someone is always looking for one. Not a whole lot of people in Boise to borrow from to test one out!!!
    Boise, Idaho
    I went ahead and got the droop - so you think I should just go ahead and put it on right out of the gate. The boat does just have a stock 454 (468) so not much power. Do I need to be thinking about a wedge or just bolt it on and go? I would imagine down the road we will also put a diverter on it for her but right now we just want to get it in the water. Thoughts?
    bolt it on and go. See how the boat reacts. Your going to need to tune it sooner or later.
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    X2
    I did the same with My 18ft Kachina before I had a place diverter. Ended up adding like a 2 or 4 degree wedge down just so it wouldnt porpoise at low speed. Still had a little porpoise sometimes but i would just go faster to make it stop. Gained around 3 or 4mph with it.
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
